Salta al contenuto principale
Polaroid Automatic 100 Bottom Frame Spring Replacement
Cosa ti serve
    1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: passo 1, immagine 1 di 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: passo 1, immagine 2 di 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: passo 1, immagine 3 di 3
      • Fully extend the bellows to prevent collapse using the #1 tab.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      Chiedi a FixBot
      Aggiungi Commento
    2. Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 2, immagine 1 di 1
      • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 3, immagine 1 di 1
      • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    4. Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 4, immagine 1 di 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 4, immagine 2 di 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 4, immagine 3 di 3
      • Remove the spring from the shutter mount.
      • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
      • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 4-3, Maness Spring 2015 Membro di Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Membri
6 guide realizzate
2Commenti sulla guida
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - Rispondi Condividi
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 35
Tutti i Tempi: 1,566
