Salta al contenuto principale
PlayStation VR LED Light Tracker Replacement
Cosa ti serve
  1. PlayStation VR LED Light Tracker Replacement, LED Light Tracker: passo 1, immagine 1 di 3 PlayStation VR LED Light Tracker Replacement, LED Light Tracker: passo 1, immagine 2 di 3 PlayStation VR LED Light Tracker Replacement, LED Light Tracker: passo 1, immagine 3 di 3
    • Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
    Chiedi a FixBot
    Aggiungi Commento
  2. PlayStation VR LED Light Tracker Replacement: passo 2, immagine 1 di 2 PlayStation VR LED Light Tracker Replacement: passo 2, immagine 2 di 2
    • Unscrew four 13 mm screws with a PH #000 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  3. PlayStation VR LED Light Tracker Replacement: passo 3, immagine 1 di 2 PlayStation VR LED Light Tracker Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tool, carefully pry the white plastic panel free from the side of the headset. Repeat this action for the opposite side.
    Chiedi a FixBot
    Aggiungi Commento
  4. PlayStation VR LED Light Tracker Replacement: passo 4, immagine 1 di 3 PlayStation VR LED Light Tracker Replacement: passo 4, immagine 2 di 3 PlayStation VR LED Light Tracker Replacement: passo 4, immagine 3 di 3
    • Use the plastic opening tool to pry the top white plastic panel free from the headset.
    • Do not try to remove the bottom plastic panel. There is a screw attaching it that must be removed first.
    • There may be a small amount of adhesive attaching the top panel to the headset, in which case you may need to use a bit more force to remove the panel.
    Chiedi a FixBot
    Aggiungi Commento
  5. PlayStation VR LED Light Tracker Replacement: passo 5, immagine 1 di 1
    • Flip the headset over.
    • Using a PH #000, unscrew the 7 mm screw found on the bottom of the headset.
    Chiedi a FixBot
    Aggiungi Commento
  6. PlayStation VR LED Light Tracker Replacement: passo 6, immagine 1 di 3 PlayStation VR LED Light Tracker Replacement: passo 6, immagine 2 di 3 PlayStation VR LED Light Tracker Replacement: passo 6, immagine 3 di 3
    • Using the plastic opening tool, pry the bottom white plastic panel loose and remove it from the headset.
    • There is adhesive attaching the panel to the headset, in which case it will take more force to remove the panel.
    Chiedi a FixBot
    Aggiungi Commento
  7. PlayStation VR LED Light Tracker Replacement: passo 7, immagine 1 di 3 PlayStation VR LED Light Tracker Replacement: passo 7, immagine 2 di 3 PlayStation VR LED Light Tracker Replacement: passo 7, immagine 3 di 3
    • Unscrew the two 7 mm screws from the top of the headset.
    Chiedi a FixBot
    Aggiungi Commento
  8. PlayStation VR LED Light Tracker Replacement: passo 8, immagine 1 di 3 PlayStation VR LED Light Tracker Replacement: passo 8, immagine 2 di 3 PlayStation VR LED Light Tracker Replacement: passo 8, immagine 3 di 3
    • Using your fingers, carefully pry the black front panel free from the headset.
    • We recommend that you start the removal from the sides by pulling them forward.
    • There is adhesive holding the front panel in place, which means you will need a bit of extra force to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  9. PlayStation VR LED Light Tracker Replacement: passo 9, immagine 1 di 1
    • Unscrew the four silver 6 mm screws in each corner using a PH #000 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  10. PlayStation VR LED Light Tracker Replacement: passo 10, immagine 1 di 3 PlayStation VR LED Light Tracker Replacement: passo 10, immagine 2 di 3 PlayStation VR LED Light Tracker Replacement: passo 10, immagine 3 di 3
    • Lift the small silver latch attaching the ZIF (zero insertion force) connector to the circuit board.
    • Carefully pull the end of the white ribbon connector from its slot.
    • Be careful not to damage or dirty the ribbon connector.
    Chiedi a FixBot
    Aggiungi Commento
  11. PlayStation VR LED Light Tracker Replacement: passo 11, immagine 1 di 2 PlayStation VR LED Light Tracker Replacement: passo 11, immagine 2 di 2
    • Unhitch the yellow led connector ribbon and move it aside.
    Chiedi a FixBot
    Aggiungi Commento
  12. PlayStation VR LED Light Tracker Replacement: passo 12, immagine 1 di 3 PlayStation VR LED Light Tracker Replacement: passo 12, immagine 2 di 3 PlayStation VR LED Light Tracker Replacement: passo 12, immagine 3 di 3
    • Carefully pry the black plastic piece attaching the yellow ribbon to the headset away from the green circuit board.
    • Remove the yellow LED ribbons and black plastic connecting piece from the headset.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Sarah Shand
Membro da: 02/20/17
1.996 Reputazione
7 guide realizzate
USF Tampa, Team S3-G1, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Membri
15 guide realizzate
1Commento della guida
where can I buy the LED lights for it??
Jordi - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 12
Ultimi 30 giorni: 56
Tutti i Tempi: 4,683
