Salta al contenuto principale
PlayStation 5 Faceplates Replacement
Cosa ti serve
  1. PlayStation 5 Faceplates Replacement, Remove the stand screw: passo 1, immagine 1 di 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Faceplates Replacement, Remove the vertical stand: passo 2, immagine 1 di 2 PlayStation 5 Faceplates Replacement, Remove the vertical stand: passo 2, immagine 2 di 2
    • Lift straight up to remove the stand.
  3. PlayStation 5 Faceplates Replacement, Store the stand screw: passo 3, immagine 1 di 2 PlayStation 5 Faceplates Replacement, Store the stand screw: passo 3, immagine 2 di 2
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Faceplates Replacement, Cap the screw hole: passo 4, immagine 1 di 3 PlayStation 5 Faceplates Replacement, Cap the screw hole: passo 4, immagine 2 di 3 PlayStation 5 Faceplates Replacement, Cap the screw hole: passo 4, immagine 3 di 3
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Faceplates Replacement, Close the cubby: passo 5, immagine 1 di 3 PlayStation 5 Faceplates Replacement, Close the cubby: passo 5, immagine 2 di 3 PlayStation 5 Faceplates Replacement, Close the cubby: passo 5, immagine 3 di 3
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Faceplates Replacement, Remove the horizontal stand: passo 6, immagine 1 di 2 PlayStation 5 Faceplates Replacement, Remove the horizontal stand: passo 6, immagine 2 di 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Faceplates Replacement, Remove the left faceplate: passo 7, immagine 1 di 3 PlayStation 5 Faceplates Replacement, Remove the left faceplate: passo 7, immagine 2 di 3 PlayStation 5 Faceplates Replacement, Remove the left faceplate: passo 7, immagine 3 di 3
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  8. PlayStation 5 Faceplates Replacement: passo 8, immagine 1 di 2 PlayStation 5 Faceplates Replacement: passo 8, immagine 2 di 2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the left faceplate.
  9. PlayStation 5 Faceplates Replacement, Remove the right faceplate: passo 9, immagine 1 di 3 PlayStation 5 Faceplates Replacement, Remove the right faceplate: passo 9, immagine 2 di 3 PlayStation 5 Faceplates Replacement, Remove the right faceplate: passo 9, immagine 3 di 3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  10. PlayStation 5 Faceplates Replacement: passo 10, immagine 1 di 2 PlayStation 5 Faceplates Replacement: passo 10, immagine 2 di 2
    • Remove the right faceplate.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
Altre 9 persone hanno completato questa guida.
Clay Kim
Membro da: 02/16/21
7.469 Reputazione
21 Guide realizzate
Un commento
Hello, thanks for the updates
hadi rp - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 111
Ultimi 30 Giorni: 483
Tutti i Tempi: 7,403
