Salta al contenuto principale
Sostituzione Ventola PlayStation 4 Pro
Cosa ti serve
  1. Sostituzione Ventola PlayStation 4 Pro, Carrello disco rigido: passo 1, immagine 1 di 3 Sostituzione Ventola PlayStation 4 Pro, Carrello disco rigido: passo 1, immagine 2 di 3 Sostituzione Ventola PlayStation 4 Pro, Carrello disco rigido: passo 1, immagine 3 di 3
    • Gira la console a faccia in giù.
    • Usa le unghie per tirare e sganciare la copertura in plastica sopra il disco rigido.
    DON’T FORGET TO HAVE THERMAL PASTE HANDY! It should be added to the “Tools Required” Section. You will NEED it!
    Jaquell Chandler - Replica
    What if thermal paste is not applied again when remounting ? Will the playstation start and work anyway or not ?
    Vincent Bee - Replica
    It will start and run normally until you put it under load. Then it will heat up and thermal throttle or it can overheat and destroy itself.
    Jeremy Ivey -
    I posted this down in another step too, but: if you have a very early North American PS4 Pro, with the exact optical drive shown here - the key way to tell is the very long data cable that’s folded a couple of times, see pictures in later steps - then the replacement drive iFixit offers WILL NOT WORK IN YOUR MACHINE. It has to be a very early model, apparently, but the model number isn’t enough to tell you.
    Even if you swap the too-short cables in their replacement with the longer cables on your drive, it still will not work. At all. It’ll just sit there like the drive isn’t even getting power.
    So if you do have this drive, what you probably need to do is get a replacement KES-496A Optical Pickup Assembly and replace that within your existing drive. That’s what I had to do after two different replacement drives sent by iFixit failed to work in my system. It worked immediately and I’m back online.
    The optical pickup replacement is awfully fiddly, and adds a solid 20 minutes to the repair easily. But it does work.
    Dara Korra'ti - Replica
    I had originally been told by several people that to properly repair the optical drive within the PS4 Pro (so that the PS4 actually works), you have to replace the Optical Pickup Assembly like you mentioned because the drive is paired with the motherboard. I was surprised to find that iFixit is pushing this repair tutorial when it has a low probability of success for many PS4 Pro models.
    Instead, iFixit should be documenting replacement of the KES-496A Optical Pickup Assembly... when that repair has a near 100% chance of success, even though it's a fair bit more fiddly to complete and requires two different teardowns (one for the PS4 Pro and one for the optical drive... needed to install the replacement optical pickup assembly).
    commorancy -
    Follow-on note. I could be mixing up the original PS4's pairing with the PS4 Pro (which might or might not have device + motherboard pairing). Because I can't find a definitive source confirming if the drive is paired on the PS4 Pro, using a drive replacement might or might not work.
    There are a number of commenters below who followed these instructions and found that the replacement drive didn't work after completing the repair. I think I'd still go with replacing the KES-496A Optical Pickup Assembly. That repair is more fiddly, but the optical assembly replacement part is a whole lot cheaper, costing less than $10 in some stores, than buying a full replacement drive at $70.
    commorancy -
  2. Sostituzione Ventola PlayStation 4 Pro: passo 2, immagine 1 di 2 Sostituzione Ventola PlayStation 4 Pro: passo 2, immagine 2 di 2
    • Usa un cacciavite a croce Phillips #1 per rimuovere l'unica vite che tiene fermo il carrello del disco rigido.
    • Sfila il carrello del disco rigido tirandolo.
    This is a Phillips #1 bit.
    Trevor Frey - Replica
  3. Sostituzione Ventola PlayStation 4 Pro, Gruppo alimentatore: passo 3, immagine 1 di 3 Sostituzione Ventola PlayStation 4 Pro, Gruppo alimentatore: passo 3, immagine 2 di 3 Sostituzione Ventola PlayStation 4 Pro, Gruppo alimentatore: passo 3, immagine 3 di 3
    • Gira la console a faccia in su.
    • Prendi i due angoli anteriori del dispositivo.
    • Tirali verso l'alto finché non senti un forte rumore.
    • Ciò potrebbe richiedere molta forza, quindi non avere paura di essere un po' rozzo con la tua console.
    • Dopo aver sganciato entrambi gli angoli, sfila la copertura all'indietro e sollevala per rimuoverla.
    %#*@. I thought I was gonna break the thing. You really do have to give it some elbow grease.
    Addison Francisco - Replica
    there were also some screws that needed to come out before popping it off. Might have been a different version im working on. there were three screws attached to the console that I had to remove before popping off the top.
    Ricky Arias - Replica
    The 7215B has one TR8 security Torx behind the center “void” sticker.
    cylentstorm - Replica
    This cover is really on there. It sounds like your breaking plastic when you pop it open. I ended up using a metal tablespoon in the corners where you should pull up to pop the cover up the first bit, worked well.
    azade91 - Replica
  4. Sostituzione Ventola PlayStation 4 Pro: passo 4, immagine 1 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 4, immagine 2 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 4, immagine 3 di 3
    • Usa un cacciavite Security Torx T8 per svitare le cinque viti dal retro del dispositivo.
    • Due viti da 31 mm.
    • Tre viti da 10 mm per i modelli 7000; Due viti grigie da 10 mm (viti superiore ed inferiore nell'immagine) se la PS4 Pro è un modello della serie 7100.
    • Rimuovi la placca in metallo tirandola verso l'alto.
    I copy the comment written by Jason at the end of this guide, because it’s better to have it here:
    This guide is for the initial release CUH-7000 models. Of note is the changes to the CUH-7100 series that do make this guide an issue. Steps 4 and 5 have a different items to note. You can damage it following this guide if you don’t adjust. There no longer 3 security screws for the case, but just one. This single screw is still covered by a warranty sticker, but the second one is a blank sticker and no screw behind it. There is also no 10mm screw in the center power supply in Step 4, it’s a support post. You still remove the 4 other screws, but you must then flip the console over and remove a T8 screw to the right on the HDD cage and another closer to the right side. You can then flip the console over again to remove the battery and plug it. Just remove all the metal plate screws to be sure, but make sure you hold the board when you flip it again or you will bend the battery prongs like I found out the hard way.
    kautame - Replica
    Oh! That explains why I stripped the middle screw. What’s a support post?
    Philippe Morin -
    Had to use TR8 instead of 10mm here.
    After I popped the top off, I got 4 out of 5 screws out. The 5 th screw for some reason, was a little bit bigger, therefore, I could not take out that screw so I could clean the heatsink and fan.
    Dixie Dawg - Replica
    Me too it’s not like another screw it’s have black and I can’t remove if you know pls tell me how i do bro ???
    Montri Meka -
    I stripped the %#*@ screw in the middle. (orange highlighting) It’s a black head and the T8 Torx Security head doesn’t work! I have a CUH-7115B. I think it’s a regular T8 or some kind of Hex head. ? I don’t know what to do now!! :(
    Philippe Morin - Replica
    As mentioned above, this guide is for the old models. 7215B: There 4 TR8 screws (2 long, 2 short) holding the plate. The middle is a support post.
  5. Sostituzione Ventola PlayStation 4 Pro: passo 5, immagine 1 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 5, immagine 2 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 5, immagine 3 di 3
    • Gira la console a faccia in giù in modo che la parte inferiore sia rivolta verso l'alto.
    • Usa un cacciavite Security Torx T8 per svitare le tre viti nere da 7 mm nella copertura posteriore. (solo per i modelli serie 7000); o una vite da 4 mm (quella centrale) per i modelli serie 7100 e l'adesivo della garanzia a sinistra.
    • Rimuovi la copertura inferiore come fatto con quella superiore. Prendi la copertura da entrambi i lati e tira verso l'alto finché non scatta. Quindi sfilala via; Sui modelli serie 7100, stai attento ai due ganci che sostituiscono le rispettive viti.
    Adding to this, the screws are not visible unless you remove the warranty stickers!
    George Diaz - Replica
    Also, the plastic on the back of the cover is prone to cracking. Be careful and undo snaps across the whole back of the panel gently!
    Nick Podrebarac - Replica
    Vielen vielen Dank. Endlich ist der jumbojet gelandet #fan
    Christian Radke - Replica
    7215B has 1 TR8 screw beneath a sticker between the optical and USB ports, and two clips (1 next to the HDD slot and 1 beneath a sticker near the power port.)
  6. Sostituzione Ventola PlayStation 4 Pro: passo 6, immagine 1 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 6, immagine 2 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 6, immagine 3 di 3
    • Usa un cacciavite Security Torx T8 per svitare le undici viti argento da 10 mm dalla placca in metallo.
    • Usa un cacciavite a croce Phillips #1 per svitare le undici viti da 4 mm dalla placca in metallo.
    • I modelli serie 7200 hanno altre 13 viti da 4 mm attorno i lati superiore e destro della placca in metallo. Queste viti sono indicate con un triangolo. Potrebbe essere valido anche per alti modelli.
    • Usa uno spudger per scollegare i tre cavi dell'antenna (due neri e uno bianco) facendo leva per sollevarli dalle loro prese.
    Noted during my replacement that the PS4 Pro appears to have additional #0 Phillips Head screws in Step 6 required to remove the metal plate from the motherboard and that the metal “X” plate in Step 11 appears to be included now in this overall metal cover for the motherboard, no longer separate, which accounts for the additional screws.
    David Carlsen - Replica
    Original pro here. Had 12 torx
    Skyler Cook - Replica
    cuh0-7216b have more philips #1 screws on metal plate on right, +13 screws :)
    Papolo0 - Replica
    (PS4 Pro) Bei mir ebenfalls 11 T8 Torx, von denen 3 Sicherheitstorx waren.
    Rebecca Dorsch - Replica
    My PS4 Pro 7115 has additional sets of #0 Phillips screws on the plate. 10x in the primary processor space (blank plate area of the graphic here), 2x over the fan, and 1x on the outside edge to clamp down on the primary processor area. Model CUH-7115B
    r0flm4k3r - Replica
    What are the 3 different antennas identifications or functionality ?
    Robert Aldred - Replica
  7. Sostituzione Ventola PlayStation 4 Pro: passo 7, immagine 1 di 2 Sostituzione Ventola PlayStation 4 Pro: passo 7, immagine 2 di 2
    • Sfila il connettore bianco della ventola dalla presa gialla sulla scheda madre.
  8. Sostituzione Ventola PlayStation 4 Pro: passo 8, immagine 1 di 2 Sostituzione Ventola PlayStation 4 Pro: passo 8, immagine 2 di 2
    • Sfila i cinque piccoli cavi blu a basso profilo collegati alla placca in metallo.
    • Solleva l'aletta di bloccaggio sul connettore ZIF del cavo a nastro largo.
    • Sfila il cavo a nastro largo dalla sua presa.
    • Non sfilare il cavo blu più grande senza sollevare l'aletta prima. Farlo può danneggiare la connessione.
    What the cable in the up left corner is for? I broke it and i’d like to know at what is it connected?
    Thanks
    Enrico Pensalfine - Replica
    The blue ribbon cables aren’t connected to the metal plate. The plate can be safely removed beforehand. The only thing one should do prior to its removal is de route the antenna cables for the WNIC.
    Robert - Replica
  9. Sostituzione Ventola PlayStation 4 Pro: passo 9, immagine 1 di 1
    • Tira verso l'alto e rimuovi la placca in metallo.
  10. Sostituzione Ventola PlayStation 4 Pro: passo 10, immagine 1 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 10, immagine 2 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 10, immagine 3 di 3
    • Gira la console a faccia in su per continuare a lavorare sulla parte superiore.
    • Tira verso l'alto il gruppo dell'alimentatore ed appoggialo sulla console.
    • Stai attento a non tirarlo troppo lontano: il gruppo è ancora collegato in un punto.
    • Prendi il connettore dietro l'alimentatore e tiralo verso l'alto.
    Why do I have to remove the PSU here? I do not see the necessity judging by the following steps.
    Alexander Bla - Replica
    This comes in handy when removing the entire motherboard which is necessary when cleaning the heat sink.
    George Diaz -
    Bonjour, Que se soit le connecteur du bloc comme celui sur la partie ps4 , il est difficile à retirer ce câblage… peut-on tirer sans risque réellement ?
    Brezu Sama - Replica
    IMPORTANT: The connector on the motherboard is very sensitive. I’d recommend using pliers to put pressure down on the connector while slowly jerking the cable out of the socket to avoid serious damage to the connector and/or motherboard that could render the PSU connection useless and require advanced soldering / rewiring.
    Daniel Larusso - Replica
    This!
    Connector was quite tight in PSU side and I ended pulling connector from motherboard resulting me getting PS5 for Christmas.
    tero -
    Also der stecke lässt sich nicht entfernen
    Slime - Replica
    Der Stecker am Netzteil (letzter Schritt) erscheint mir ungewöhnlich fest, und lässt sich ohne weiteres nicht entfernen. Besteht die Möglichkeit, dass dieser neuerdings verklebt ist oder dergleichen? :-/
    Das würde mich auch interessieren. Ich habe den Stecker weder vom Mainboartd noch von der PSU abbekommen. Leider habe ich den Stecker dann abgerissen - aber er hat sich auf keiner Seite abziehen lassen.
    Tobias August -
    Bei dieser Stecker-Buchse Verbindung handelt es sich um einen Molex-Stecker, der verriegelt ist. An der Seite befindet sie ein kleiner Hebel, den man nach innen drücken muss, damit sich der Stecker löst.
    Volker Diederichs - Replica
    Danke für die Info!
    Fabian Neidhardt -
  11. Sostituzione Ventola PlayStation 4 Pro, Scheda Madre: passo 11, immagine 1 di 3 Sostituzione Ventola PlayStation 4 Pro, Scheda Madre: passo 11, immagine 2 di 3 Sostituzione Ventola PlayStation 4 Pro, Scheda Madre: passo 11, immagine 3 di 3
    • Con delicatezza gira la console in modo tale che il fondo della stessa sia girata verso l'alto.
    • Usa un cacciavite Phillips #1 per rimuovere le otto viti da 4 mm sulla piastra metallica con il simbolo ad X.
    • Usa uno strumento di apertura in plastica per rimuovere la piastra metallica con la forma ad X sopra.
    My PS4 Pro 7115, this and more is integrated with the main plate, as noted above, plus there are 10 in this area (not 8), along with 2 over the fan and 1 to the edge of this area. Model CUH-7115B
    r0flm4k3r - Replica
  12. Sostituzione Ventola PlayStation 4 Pro: passo 12, immagine 1 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 12, immagine 2 di 3 Sostituzione Ventola PlayStation 4 Pro: passo 12, immagine 3 di 3
    • Usa un cacciavite Phillips #1 per rimuovere le quattro viti da 13 mm sotto la piastra metallica a forma di X.
    • Afferra la staffa di fissaggio a forma di X e alzala.
    Mine had an S shape with two screws.
    Christopher - Replica
    Depending on the series it will have either a S or X shape bracket
    Jeremy Ivey -
    My PS4 Pro 7115 has an S-shaped bracket with 2 screws. Model CUH-7115B
    r0flm4k3r - Replica
    I have heatsink issue 7016 (x-shaped). However I am only able to find S shaped heatsink plate (71xx model) in my country. Does anyone know how the heatpipes travel within the heatsink? I basically need to drill 2 more holes and thread it to put the x clamp. Also the hole and thread size would be helpful.
    rn nr - Replica
  13. Sostituzione Ventola PlayStation 4 Pro: passo 13, immagine 1 di 2 Sostituzione Ventola PlayStation 4 Pro: passo 13, immagine 2 di 2
    • Afferra il bordo della scheda madre e lentamente alzala per rimuoverla dal dispositivo.
    • Per riassemblarla, usa questa guida per applicare nuovamente la pasta termica tra la scheda madre e la piastra metallica sottostante.
    Does anybody know the name of the white detail from the first screenshot step #13? (Plastic with square metal inside). I broke it by accident during dissembling and want to find replacement for it, but can’t find it anywhere.
    serjgord - Replica
    I can read F2-4 >POM< on the plastic piece but i guess thisis a radiator/thermal dissipator support. HTH
    Vincent Bee -
    Won't you also need a paired optical drive to replace the motherboard? My ps4 got broken some weeks ago and I've found out that I need to replace the motherboard for it to work again, but I keep seeing that you also need a paired optical drive. Is this true? My ps4 pro is a CUH-7216B if that helps
    Jekabs Freimanis - Replica
    A warning should be before this step that this step detaches from the primary heat sync. The required tools should list the replacement thermal paste at the beginning, not after the step is already to have been completed.
    r0flm4k3r - Replica
    tut euch selbst den gefallen und tauscht auch alle Wärmeleitpads. (ca 14 stück)
    Jim Bean - Replica
  14. Sostituzione Ventola PlayStation 4 Pro, Heat Pipe: passo 14, immagine 1 di 2 Sostituzione Ventola PlayStation 4 Pro, Heat Pipe: passo 14, immagine 2 di 2
    • Usa un cacciavite Phillips #1 per rimuovere le due viti argentate da 6 mm dalla piastra metallica.
    Where to get the pink stuff from?
    Dark Flo - Replica
    #1 Philips screwdriver
    Peter - Replica
  15. Sostituzione Ventola PlayStation 4 Pro: passo 15, immagine 1 di 2 Sostituzione Ventola PlayStation 4 Pro: passo 15, immagine 2 di 2
    • Alza la piastra metallica che è collegata all'heat pipe verso l'alto per rimuovere il tutto.
    The second screw is at the right bottom side !!
    mobilas77 - Replica
  16. Sostituzione Ventola PlayStation 4 Pro, Ventola: passo 16, immagine 1 di 3 Sostituzione Ventola PlayStation 4 Pro, Ventola: passo 16, immagine 2 di 3 Sostituzione Ventola PlayStation 4 Pro, Ventola: passo 16, immagine 3 di 3
    • Usa un cacciavite Phillips #0 per rimuovere le due viti da 6 mm sulla ventola.
    • Afferra la ventola e alzala per rimuoverla dall'alloggiamento.
    Screw position indicated is slightly wrong. Both screws are on the right side of the fan. The one on the right is in the correct place. The other is below it rather than to the left as indicated.
    Paul Swinglehurst - Replica
Conclusione
Per riassemblare il dispositivo, segui le istruzioni nell'ordine inverso.
Altre 110 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Acn0w ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Thomas
Membro da: 04/26/17
3.877 Reputazione
5 Guide realizzate
Cal Poly, Team S21-G5, Livingston Spring 2017 Membro di Cal Poly, Team S21-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G5
4 Membri
49 Guide realizzate
13 Commenti
Danke für die Anleitung. hat alles super geklappt. Bloß beim letzten Schritt ist die Schraube vom Lüfter nicht oben links sondern unten rechts. Mfg
Camorrista31 - Replica
Thanks for the guide. Very comprehensive.
I’m clueless with electronics but my PS4 was on its death throes with overheating. I read this guide and watched the video (coffee break included) and got to work. The only trouble I had was that my husband (he’s a good guy normally) decided to help and used too big pliers and broke the connector between the power supply and PS4. Ok, so 5 days wait for replacement. I replaced the fan, thermal paste, and pads and put it back together (shaking like a leaf in a hurricane). It’s quiet and works thanks to ifixit.com. Thank you so much!
K. Birks - Replica
This was super helpful! For the power supply, I was trying to pull at the socket the cable was plugged into (same color plastic). I think it would have worked better just wiggling the cable.
Also, T8 worked fine, but putting it back together, I noticed T9 was better fit, so if you have a T9, use that instead. After cleaning and repasting, it’s so much quieter. Thanks!
Phil - Replica
Great guide. I did have a little difficulty getting the power supply connector removed, but I tried to be patient and eventually got it. Thanks!
JTG - Replica
This is perfect, I love pictures instead of video.
For the PS cable to the MB, I used a small flathead screwdriver on the top of the plug, there is a bit of a lip there allowing me to make small twists to pry the plugout.
Once the plug started to move it came right out.
If there was a picture of the plug out of the port, it would have made it easier for me, at first I was unsure what I was trying to unplug.
fjreoespt - Replica
tak, jeg brugte guiden til at rense min blæser, som næsten var helt blokeret med støv, og derfor larmet som et jetfly.
Nu køre min PS4 uden larm igen:)
men jeg forstår ikke at sony, har bygget PS4 så man skal skille den helt af for at rense blæser, virkeligt dårligt bygget.
så derfor rart med denne guide.
ps. mit PSU stik sad også meget fast, så jeg tog stikket i boardet, da det er nemmere at få godt fat i.
Svend Viborg - Replica
I just completed this on my ps4 pro cuh7015b. Disconnecting the power supply did give me a little challenge. Overall very helpful.
Nick Swan - Replica
Very easy to follow instructions, helped me clear out a very dusty fan!
jackacon - Replica
Awesome guide. I'm not very familiar with electronics but I was able to do this pretty easy. Just be easy with the power supply connector, it's alittle tight but just keep at it by hand. DON'T do what I did and grab some pliers!!! I was able to repair the cable I damaged but I was very lucky, as it only broke the casing and not the wire inside.
William Campbell - Replica
my PS4 pro model 7100 had one of the clips (the right one) behind another sticker. took me a bit to find and remove it. additionally, when trying to remove the power supply, at the top there was an additional screw. it looks like it needs one of those tools that you use to build IKEA furniture (yk the L-shaped kind. I could not find a fitting one and had to give up. this was pretty frustrating
Elfi - Replica
7200 model, sorry
Elfi -
Very useful for full disassembly, deep clean, and repaste. Thermal paste should be included in supplies list though.
Jesse Campbell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 56
Ultimi 7 Giorni: 356
Ultimi 30 Giorni: 1,790
Tutti i Tempi: 156,835
