Salta al contenuto principale
Plantronics CS50 Headset System Reset
  1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: passo 1, immagine 1 di 2 Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: passo 1, immagine 2 di 2
    • Press and hold both the call control button and the listening volume/mute button for five seconds.
    • When the talk indicator light blinks, release both buttons.
    Chiedi a FixBot
    Aggiungi Commento
  2. Plantronics CS50 Headset System Reset: passo 2, immagine 1 di 1
    • Press the call control button again.
    Chiedi a FixBot
    Aggiungi Commento
  3. Plantronics CS50 Headset System Reset: passo 3, immagine 1 di 2 Plantronics CS50 Headset System Reset: passo 3, immagine 2 di 2
    • Unplug the base unit's power source for ten seconds.
    • Plug the power source back in.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Joe
Membro da: 04/12/12
117 Reputazione
3 guide realizzate
Cal Poly, Team 17-29, Amido Spring 2012 Membro di Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Membri
21 guide realizzate
4Commenti sulla guida
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - Rispondi Condividi
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - Rispondi Condividi
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - Rispondi Condividi
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 12
Ultimi 30 giorni: 38
Tutti i Tempi: 23,434
