Introduzione
If you need to reinstall a new LCD Housing unit then use this guide. For his guide, you will need mainly a Phillips #00 screwdriver head and any other tools that were used in the prerequisite guides such as a Spudger or iFixit Opening Tool. Will will not need to do any difficult steps but this guide will be time consuming.
Cosa ti serve
Remove the four silicone feet on the bottom plate.
Remove the following Phillips screws from the bottom plate:
Two 9 mm screws
Two 13 mm screws
Use an opening pick to pry underneath the plastic covering the edges of the screen.
Place an opening tool in the space made between the screen and this plastic piece and pry up, working around the length of this circular piece to significantly loosen it.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
