Salta al contenuto principale
Philips SBA1060 Capacitor Replacement
Cosa ti serve
  1. Philips SBA1060 Capacitor Replacement, Battery Casing: passo 1, immagine 1 di 1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
    Chiedi a FixBot
    Aggiungi Commento
  2. Philips SBA1060 Capacitor Replacement: passo 2, immagine 1 di 3 Philips SBA1060 Capacitor Replacement: passo 2, immagine 2 di 3 Philips SBA1060 Capacitor Replacement: passo 2, immagine 3 di 3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
    Chiedi a FixBot
    Aggiungi Commento
  3. Philips SBA1060 Capacitor Replacement: passo 3, immagine 1 di 2 Philips SBA1060 Capacitor Replacement: passo 3, immagine 2 di 2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
    Chiedi a FixBot
    Aggiungi Commento
  4. Philips SBA1060 Capacitor Replacement, Capacitor: passo 4, immagine 1 di 1
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Slowly pull the circuit board out of the device
    • NOTE: Be careful not to damage any of the wires protruding from the back of the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  5. Philips SBA1060 Capacitor Replacement: passo 5, immagine 1 di 2 Philips SBA1060 Capacitor Replacement: passo 5, immagine 2 di 2
    • Flip the device and remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
    Chiedi a FixBot
    Aggiungi Commento
  6. Philips SBA1060 Capacitor Replacement: passo 6, immagine 1 di 2 Philips SBA1060 Capacitor Replacement: passo 6, immagine 2 di 2
    • Locate the capacitor and carefully slide it out of the circuit board.
    • NOTE: The capacitor will be a cylindrical object protruding vertically near the center of the circuit board.
    • Slide the prongs of the replacement capacitor into the two holes of the circuit board where the original capacitor was removed from.
    • Reassemble the speaker.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Clemson, Team 14-4, Benson Fall 2013 Membro di Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
3 Membri
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 22
Tutti i Tempi: 1,044
