Salta al contenuto principale
Pentax Super Program Shutter Service
Cosa ti serve
    1. Pentax Super Program Shutter Service, Remove film advance lever: passo 1, immagine 1 di 3 Pentax Super Program Shutter Service, Remove film advance lever: passo 1, immagine 2 di 3 Pentax Super Program Shutter Service, Remove film advance lever: passo 1, immagine 3 di 3
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax Super Program Shutter Service, Remove mode dial: passo 2, immagine 1 di 2 Pentax Super Program Shutter Service, Remove mode dial: passo 2, immagine 2 di 2
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax Super Program Shutter Service, Remove exposure compensation dial: passo 3, immagine 1 di 3 Pentax Super Program Shutter Service, Remove exposure compensation dial: passo 3, immagine 2 di 3 Pentax Super Program Shutter Service, Remove exposure compensation dial: passo 3, immagine 3 di 3
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax Super Program Shutter Service, Remove top cover screws: passo 4, immagine 1 di 3 Pentax Super Program Shutter Service, Remove top cover screws: passo 4, immagine 2 di 3 Pentax Super Program Shutter Service, Remove top cover screws: passo 4, immagine 3 di 3
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax Super Program Shutter Service, Remove top cover: passo 5, immagine 1 di 3 Pentax Super Program Shutter Service, Remove top cover: passo 5, immagine 2 di 3 Pentax Super Program Shutter Service, Remove top cover: passo 5, immagine 3 di 3
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax Super Program Shutter Service, Remove bottom cover: passo 6, immagine 1 di 1
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax Super Program Shutter Service, Remove front leatherette panels: passo 7, immagine 1 di 3 Pentax Super Program Shutter Service, Remove front leatherette panels: passo 7, immagine 2 di 3 Pentax Super Program Shutter Service, Remove front leatherette panels: passo 7, immagine 3 di 3
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax Super Program Shutter Service, Detach flex PCB with adjustment pots: passo 8, immagine 1 di 2 Pentax Super Program Shutter Service, Detach flex PCB with adjustment pots: passo 8, immagine 2 di 2
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax Super Program Shutter Service, Unsolder motor drive connections: passo 9, immagine 1 di 2 Pentax Super Program Shutter Service, Unsolder motor drive connections: passo 9, immagine 2 di 2
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax Super Program Shutter Service, Remove tripod mount: passo 10, immagine 1 di 2 Pentax Super Program Shutter Service, Remove tripod mount: passo 10, immagine 2 di 2
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax Super Program Shutter Service, Detach ISO resistor assembly: passo 11, immagine 1 di 2 Pentax Super Program Shutter Service, Detach ISO resistor assembly: passo 11, immagine 2 di 2
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      Chiedi a FixBot
      Aggiungi Commento
    6. Pentax Super Program Shutter Service, Detach mode dial unit: passo 12, immagine 1 di 3 Pentax Super Program Shutter Service, Detach mode dial unit: passo 12, immagine 2 di 3 Pentax Super Program Shutter Service, Detach mode dial unit: passo 12, immagine 3 di 3
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      Chiedi a FixBot
      Aggiungi Commento
    7. Pentax Super Program Shutter Service, Unsolder flash sync wires: passo 13, immagine 1 di 1
      • Unsolder two gray wires.
      Chiedi a FixBot
      Aggiungi Commento
    8. Pentax Super Program Shutter Service, Unsolder shutter wires: passo 14, immagine 1 di 2 Pentax Super Program Shutter Service, Unsolder shutter wires: passo 14, immagine 2 di 2
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      Chiedi a FixBot
      Aggiungi Commento
    9. Pentax Super Program Shutter Service, Unscrew mirror box: passo 15, immagine 1 di 2 Pentax Super Program Shutter Service, Unscrew mirror box: passo 15, immagine 2 di 2
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      Chiedi a FixBot
      Aggiungi Commento
    10. Pentax Super Program Shutter Service, Unscrew front board: passo 16, immagine 1 di 2 Pentax Super Program Shutter Service, Unscrew front board: passo 16, immagine 2 di 2
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      Chiedi a FixBot
      Aggiungi Commento
    11. Pentax Super Program Shutter Service, Remove mirror box and front board: passo 17, immagine 1 di 1
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      Chiedi a FixBot
      Aggiungi Commento
    12. Pentax Super Program Shutter Service, Installation Notes: Front Block: passo 18, immagine 1 di 1
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax Super Program Shutter Service, Remove shutter unit: passo 19, immagine 1 di 3 Pentax Super Program Shutter Service, Remove shutter unit: passo 19, immagine 2 di 3 Pentax Super Program Shutter Service, Remove shutter unit: passo 19, immagine 3 di 3
      • Lift shutter unit out of camera body.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax Super Program Shutter Service, Release the shutter: passo 20, immagine 1 di 1
      • Push the shutter release latch down to fire the shutter.
      • Reducing the tension of the shutter springs makes disassembly and reassembly easier.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax Super Program Shutter Service, Remove rear plate: passo 21, immagine 1 di 3 Pentax Super Program Shutter Service, Remove rear plate: passo 21, immagine 2 di 3 Pentax Super Program Shutter Service, Remove rear plate: passo 21, immagine 3 di 3
      • Remove old foam seals.
      • Foam seals should be replaced with new material during reassembly.
      • Remove four M1.4 x 2.4 mm screws.
      • Remove top spacer bushing.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax Super Program Shutter Service, Remove closing curtain: passo 22, immagine 1 di 2 Pentax Super Program Shutter Service, Remove closing curtain: passo 22, immagine 2 di 2
      • Remove closing curtain linkage.
      • Remove five curtain blades.
      • Installation Notes: Make sure the helper spring is properly hooked on the closing curtain linkage when reassembled.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax Super Program Shutter Service, Remove curtain separator: passo 23, immagine 1 di 2 Pentax Super Program Shutter Service, Remove curtain separator: passo 23, immagine 2 di 2
      • Remove curtain separator.
      • Remove lower separator bushing.
      Chiedi a FixBot
      Aggiungi Commento
    6. Pentax Super Program Shutter Service, Remove opening curtain: passo 24, immagine 1 di 2 Pentax Super Program Shutter Service, Remove opening curtain: passo 24, immagine 2 di 2
      • Remove three curtain blades.
      • Remove opening curtain linkage.
      Chiedi a FixBot
      Aggiungi Commento
    7. Pentax Super Program Shutter Service, Clean the shutter: passo 25, immagine 1 di 3 Pentax Super Program Shutter Service, Clean the shutter: passo 25, immagine 2 di 3 Pentax Super Program Shutter Service, Clean the shutter: passo 25, immagine 3 di 3
      • Remove two curtain guides.
      • Clean any residue from the shutter frame and blades using isopropyl alcohol or other solvent.
      • Clean the curtain pivots.
      • Remove degraded rubber dampers and clean the surrounding area. They do not need to be replaced.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Sam Gustafson
Membro da: 09/01/22
14.484 Reputazione
78 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 17
Ultimi 30 giorni: 44
Tutti i Tempi: 663
