Salta al contenuto principale
Pentax PZ-10 Button Replacement
Cosa ti serve
  1. Pentax PZ-10 Button Replacement, Top Cover: passo 1, immagine 1 di 1
    • The top cover is one piece encasing the top of the device except the shutter release button and flash.
    Chiedi a FixBot
    Aggiungi Commento
  2. Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: passo 2, immagine 1 di 2 Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: passo 2, immagine 2 di 2
    • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
    • Using the J0 screwdriver, remove the 6.3 mm screw.
    Chiedi a FixBot
    Aggiungi Commento
  3. Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: passo 3, immagine 1 di 2 Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: passo 3, immagine 2 di 2
    • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
    • Remove the 6.3 mm screw using a J0 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: passo 4, immagine 1 di 2 Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: passo 4, immagine 2 di 2
    • The next screw is found in the overhanging piece just above the lens.
    • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  5. Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: passo 5, immagine 1 di 2 Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: passo 5, immagine 2 di 2
    • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  6. Pentax PZ-10 Button Replacement, Locate Rubber Tabs: passo 6, immagine 1 di 2 Pentax PZ-10 Button Replacement, Locate Rubber Tabs: passo 6, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Gently remove the beige rubber tabs from under the casing by pulling each down using tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  7. Pentax PZ-10 Button Replacement: passo 7, immagine 1 di 1
    • Remove the 3 buttons by pushing them from under the casing out through the top.
    • Each button is slotted differently, so pay attention to the orientation of each piece.
    Chiedi a FixBot
    Aggiungi Commento
  8. Pentax PZ-10 Button Replacement, Buttons: passo 8, immagine 1 di 1
    • The buttons are now free to be replaced or cleaned.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 19
Tutti i Tempi: 833
