Salta al contenuto principale
Pentax PZ-10 Back Cover Locking Switch Spring Replacement
Cosa ti serve
    1. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Bottom Cover: passo 1, immagine 1 di 1
      • With the lens face up and the bottom panel of the camera facing you, remove the two 7mm screws on the left using the J0 screwdriver.
      • Remove the six 4.3mm screws in the middle and right of the panel using the J0 screwdriver.
      • Pull off the bottom casing to remove.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing Bottom Casing: passo 2, immagine 1 di 1
      • With the screws removed, the bottom casing should come off very easily by pulling on the casing.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Back Cover: passo 3, immagine 1 di 1
      • Place the camera on its side so the lens is facing left.
      • Press down on the locking switch on the side panel facing you.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: passo 4, immagine 1 di 1
      • With the door unlocked, rotate the device to access the bottom.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: passo 5, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Using a pair of tweezers, gently remove the metal tab securing the back door axle.
      • The door will come loose at this point, watch for any loose parts that may also come out.
      Chiedi a FixBot
      Aggiungi Commento
    6. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Side Panel: passo 6, immagine 1 di 1
      • Once the back cover is fully removed, remove the two 4.35mm screws attaching the cover of the unlocking switch, and remove the plate.
      Chiedi a FixBot
      Aggiungi Commento
    7. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Spring: passo 7, immagine 1 di 1
      • Locate the spring at the upper left corner of the face, and pull the rings of the spring off of the pins to remove it using plastic opening tools.
      • You are now ready to replace the spring.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Ryan Su
Membro da: 04/20/15
107 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 17
Tutti i Tempi: 738
