Salta al contenuto principale
Peavy 4 String Bass String Replacement
Cosa ti serve
    1. Peavy 4 String Bass String Replacement, Strings: passo 1, immagine 1 di 1
      • Spin the pegs in the direction which loosens the string. Either unwind the string all the way and pull it out, or cut the string after loosening it a little.
      • Repeat for all the other strings.
      Chiedi a FixBot
      Aggiungi Commento
    2. Peavy 4 String Bass String Replacement: passo 2, immagine 1 di 1
      • Now that you have a bass with no strings, grab your choice of bass strings, take them out of the bag and unwind them so they are straight.
      Chiedi a FixBot
      Aggiungi Commento
    3. Peavy 4 String Bass String Replacement: passo 3, immagine 1 di 1
      • Pick up your ropes and arrange them in order from thickest to thinnest, sorting from bottom to top.
      Chiedi a FixBot
      Aggiungi Commento
    4. Peavy 4 String Bass String Replacement: passo 4, immagine 1 di 1
      • Starting with the thickest string (E string), feed the string through the left-most hole at the base of the bridge (pictured left).
      • Repeat what you did with the E string with next thickest string (A string).
      • Repeat again for the next thinnest (D string), and again for the thinnest string (G string).
      Chiedi a FixBot
      Aggiungi Commento
    5. Peavy 4 String Bass String Replacement: passo 5, immagine 1 di 1
      • Pull the strings all the way through so the pegs at the end of the strings are touching the bridge.
      Chiedi a FixBot
      Aggiungi Commento
    6. Peavy 4 String Bass String Replacement: passo 6, immagine 1 di 1
      • Starting with the E string, make sure the string is in line with the correct notch on the nut.
      • Locate the hole in the guide and feed the string through the hole so it sticks out about one centimeter.
      • Rotate the tuning peg so that the string rotates counter-clockwise until the string is taut.
      • Repeat for the other 3 strings.
      Chiedi a FixBot
      Aggiungi Commento
    7. Peavy 4 String Bass String Replacement: passo 7, immagine 1 di 1
      • Make sure the strings are wrapped around the peg in the correct direction as shown.
      • If any mistakes were made, you can always unwind the string and try it again.
      Chiedi a FixBot
      Aggiungi Commento
      • Once all the strings are taut, begin tuning each string.
      • Now you have a bass with fresh strings!
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
In order to get your bass sounding brand new again follow these steps and youll get a wonderful result
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 29
Tutti i Tempi: 724
