Salta al contenuto principale
Pantech Breakout Micro SD/SIM Card Replacement
  1. Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: passo 1, immagine 1 di 3 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: passo 1, immagine 2 di 3 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: passo 1, immagine 3 di 3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: passo 2, immagine 1 di 2 Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: passo 2, immagine 2 di 2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
    Chiedi a FixBot
    Aggiungi Commento
  3. Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: passo 3, immagine 1 di 2 Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: passo 3, immagine 2 di 2
    • The slots for the Micro SD and SIM cards are directly above the battery tray.
    • To insert a card, slide it face up into the slot. To remove a card, slide the card out from the slot.
    • Micro SD Card Slot - On the Left
    • SIM Card Slot - On the Right
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Ryan Murphy
Membro da: 09/25/14
898 Reputazione
7 guide realizzate
USF Tampa, Team 5-5, Mcgee Fall 2014 Membro di USF Tampa, Team 5-5, Mcgee Fall 2014
USFT-MCGEE-F14S5G5
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 6
Ultimi 30 giorni: 31
Tutti i Tempi: 2,939
