Salta al contenuto principale
Pantech Breakout Battery Replacement
Cosa ti serve
  1. Pantech Breakout Battery Replacement, Removing Back Cover: passo 1, immagine 1 di 3 Pantech Breakout Battery Replacement, Removing Back Cover: passo 1, immagine 2 di 3 Pantech Breakout Battery Replacement, Removing Back Cover: passo 1, immagine 3 di 3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Pantech Breakout Battery Replacement, Removing the Battery: passo 2, immagine 1 di 2 Pantech Breakout Battery Replacement, Removing the Battery: passo 2, immagine 2 di 2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Ryan Murphy
Membro da: 09/25/14
898 Reputazione
7 guide realizzate
USF Tampa, Team 5-5, Mcgee Fall 2014 Membro di USF Tampa, Team 5-5, Mcgee Fall 2014
USFT-MCGEE-F14S5G5
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 25
Tutti i Tempi: 2,218
