Salta al contenuto principale
Panasonic SA-HT810V VHS Drive Replacement
Cosa ti serve
    1. Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: passo 1, immagine 1 di 3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: passo 1, immagine 2 di 3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: passo 1, immagine 3 di 3
      • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
      • Now rotate the device 180 degrees and remove the second screw.
      • Remove the screw that is on the right side of the panel facing you.
      • All screws will need to be removed with a phillips head screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Panasonic SA-HT810V VHS Drive Replacement: passo 2, immagine 1 di 2 Panasonic SA-HT810V VHS Drive Replacement: passo 2, immagine 2 di 2
      • Rotate the device so that the back faces you.
      • With a phillips heat screwdriver, locate and remove the four screws highlighted by the red circles in image one.
      Chiedi a FixBot
      Aggiungi Commento
    3. Panasonic SA-HT810V VHS Drive Replacement: passo 3, immagine 1 di 1
      • Before removing cover make sure that the back of the device is facing you.
      • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
      Chiedi a FixBot
      Aggiungi Commento
    4. Panasonic SA-HT810V VHS Drive Replacement: passo 4, immagine 1 di 3 Panasonic SA-HT810V VHS Drive Replacement: passo 4, immagine 2 di 3 Panasonic SA-HT810V VHS Drive Replacement: passo 4, immagine 3 di 3
      • Pull up the two tabs on top
      • Pull the the three tabs on the side there is one on the left and two and the right side of the device when it is facing you.
      • Depress the four tabs on the bottom of the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. Panasonic SA-HT810V VHS Drive Replacement: passo 5, immagine 1 di 1
      • Carefully pull off the front panel of the device.
      • The front is attached to the device with cables so be careful when removing.
      Chiedi a FixBot
      Aggiungi Commento
    6. Panasonic SA-HT810V VHS Drive Replacement: passo 6, immagine 1 di 2 Panasonic SA-HT810V VHS Drive Replacement: passo 6, immagine 2 di 2
      • With the device front facing you remove the six screws with a phillips head screwdriver around the VHS drive.
      Chiedi a FixBot
      Aggiungi Commento
    7. Panasonic SA-HT810V VHS Drive Replacement: passo 7, immagine 1 di 1
      • Remove the three cables attaching the VHS to the Mother Board.
      • Carefully pull the VHS drive out of the device and follow the steps in reverse to place the new one in.
      • Make sure the cables connecting the VHS Drive are fully inserted before powering the machine on to prevent damage to the internal components.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 16-5, Maness Spring 2010 Membro di Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Membri
22 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 38
Tutti i Tempi: 1,503
