Salta al contenuto principale
Panasonic KX-TGE233 Power Port Replacement
Cosa ti serve
  1. Panasonic KX-TGE233 Power Port Replacement, Base Front Panel Assembly: passo 1, immagine 1 di 1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 Power Port Replacement: passo 2, immagine 1 di 1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 Power Port Replacement: passo 3, immagine 1 di 1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 Power Port Replacement: passo 4, immagine 1 di 1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 Power Port Replacement: passo 5, immagine 1 di 1
    • With the back removed, we now have direct access to all other components in the main docking station.
  6. Panasonic KX-TGE233 Power Port Replacement, Power Port: passo 6, immagine 1 di 1
    • Now that the device has been opened, the power port can easily be removed from its resting point.
  7. Panasonic KX-TGE233 Power Port Replacement: passo 7, immagine 1 di 1
  8. Panasonic KX-TGE233 Power Port Replacement: passo 8, immagine 1 di 1
    • The faulty power port can now be detached from the device from its contact points. If soldering has been successful, removal should require minimal effort.
Conclusione
Nico Cruz
Membro da: 02/09/16
249 Reputazione
2 Guide realizzate
IUPUI, Team 2-2, Baechle Spring 2016 Membro di IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,146
