Salta al contenuto principale
Panasonic DMC-FZ70 Back Panel Replacement
Cosa ti serve
    1. Panasonic DMC-FZ70 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 Panasonic DMC-FZ70 Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
      • All screws should be removed using a Phillips #0 screwdriver.
      • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
      Chiedi a FixBot
      Aggiungi Commento
    2. Panasonic DMC-FZ70 Back Panel Replacement: passo 2, immagine 1 di 2 Panasonic DMC-FZ70 Back Panel Replacement: passo 2, immagine 2 di 2
      • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
      Chiedi a FixBot
      Aggiungi Commento
    3. Panasonic DMC-FZ70 Back Panel Replacement: passo 3, immagine 1 di 2 Panasonic DMC-FZ70 Back Panel Replacement: passo 3, immagine 2 di 2
      • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
      Chiedi a FixBot
      Aggiungi Commento
    4. Panasonic DMC-FZ70 Back Panel Replacement: passo 4, immagine 1 di 2 Panasonic DMC-FZ70 Back Panel Replacement: passo 4, immagine 2 di 2
      • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
      • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
      Chiedi a FixBot
      Aggiungi Commento
    5. Panasonic DMC-FZ70 Back Panel Replacement: passo 5, immagine 1 di 1
      • Proceed to remove the four 5mm Phillips screws that you just uncovered.
      Chiedi a FixBot
      Aggiungi Commento
    6. Panasonic DMC-FZ70 Back Panel Replacement: passo 6, immagine 1 di 1
      • Slowly pull on both side of the camera, until both halves begin to separate from each other.
      • Do not pull too hard, as both halves are held together with ZIF connector cables.
      Chiedi a FixBot
      Aggiungi Commento
    7. Panasonic DMC-FZ70 Back Panel Replacement: passo 7, immagine 1 di 3 Panasonic DMC-FZ70 Back Panel Replacement: passo 7, immagine 2 di 3 Panasonic DMC-FZ70 Back Panel Replacement: passo 7, immagine 3 di 3
      • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
      • Carefully pull the ribbon cables out of the slot once they have been released.
      • Only the two indicated connectors need to be removed to separate the two halves of the camera.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 21-3, Maness Winter 2017 Membro di Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 12
Ultimi 30 giorni: 32
Tutti i Tempi: 1,180
