Salta al contenuto principale
Panasonic DECT 6.0 Button Replacement
Cosa ti serve
    1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: passo 1, immagine 1 di 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: passo 1, immagine 2 di 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: passo 1, immagine 3 di 3
      • Remove the battery cover by pushing the tab upwards and sliding it off.
      • Pull out the battery/energy source from its slot.
      • Keep all pieces in a safe and orderly manner for ease of reassembly.
      Chiedi a FixBot
      Aggiungi Commento
    2. Panasonic DECT  6.0 Button Replacement: passo 2, immagine 1 di 3 Panasonic DECT  6.0 Button Replacement: passo 2, immagine 2 di 3 Panasonic DECT  6.0 Button Replacement: passo 2, immagine 3 di 3
      • Unscrew the screws you see on the inside of the casing using an appropriate screwdriver from the JIS Driver Set.
      • Carefully pry each side open with the iFixit Opening tool.
      • Detach the back of the phone case.
      Chiedi a FixBot
      Aggiungi Commento
    3. Panasonic DECT  6.0 Button Replacement: passo 3, immagine 1 di 3 Panasonic DECT  6.0 Button Replacement: passo 3, immagine 2 di 3 Panasonic DECT  6.0 Button Replacement: passo 3, immagine 3 di 3
      • Unscrew the screws to remove the motherboard using an appropriate screwdriver from the JIS Driver Set.
      • Potential for device damage
      Chiedi a FixBot
      Aggiungi Commento
    4. Panasonic DECT  6.0 Button Replacement: passo 4, immagine 1 di 3 Panasonic DECT  6.0 Button Replacement: passo 4, immagine 2 di 3 Panasonic DECT  6.0 Button Replacement: passo 4, immagine 3 di 3
      • Carefully pull off the circuitry and cords from the front half of the phone and set them aside.
      • Bring the buttons to the front.
      Chiedi a FixBot
      Aggiungi Commento
    5. Panasonic DECT  6.0 Button Replacement: passo 5, immagine 1 di 2 Panasonic DECT  6.0 Button Replacement: passo 5, immagine 2 di 2
      • Pull gently to separate the button pad from the phone cover.
      • Identify the broken/jammed button you were having issues with.
      • Replace or return the button to its function.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Jacob
Membro da: 05/31/16
131 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 23
Tutti i Tempi: 947
