Salta al contenuto principale
PSP 300x Trigger Buttons Replacement
Cosa ti serve
  1. PSP 300x Trigger Buttons Replacement, Battery: passo 1, immagine 1 di 3 PSP 300x Trigger Buttons Replacement, Battery: passo 1, immagine 2 di 3 PSP 300x Trigger Buttons Replacement, Battery: passo 1, immagine 3 di 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  2. PSP 300x Trigger Buttons Replacement, Front Casing: passo 2, immagine 1 di 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    Chiedi a FixBot
    Aggiungi Commento
  3. PSP 300x Trigger Buttons Replacement: passo 3, immagine 1 di 2 PSP 300x Trigger Buttons Replacement: passo 3, immagine 2 di 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
    Chiedi a FixBot
    Aggiungi Commento
  4. PSP 300x Trigger Buttons Replacement: passo 4, immagine 1 di 1
    • Next, unscrew the two screws located at the top of the PSP.
    Chiedi a FixBot
    Aggiungi Commento
  5. PSP 300x Trigger Buttons Replacement: passo 5, immagine 1 di 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    Chiedi a FixBot
    Aggiungi Commento
  6. PSP 300x Trigger Buttons Replacement: passo 6, immagine 1 di 2 PSP 300x Trigger Buttons Replacement: passo 6, immagine 2 di 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    Chiedi a FixBot
    Aggiungi Commento
  7. PSP 300x Trigger Buttons Replacement, LCD Screen: passo 7, immagine 1 di 2 PSP 300x Trigger Buttons Replacement, LCD Screen: passo 7, immagine 2 di 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    Chiedi a FixBot
    Aggiungi Commento
  8. PSP 300x Trigger Buttons Replacement: passo 8, immagine 1 di 3 PSP 300x Trigger Buttons Replacement: passo 8, immagine 2 di 3 PSP 300x Trigger Buttons Replacement: passo 8, immagine 3 di 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    Chiedi a FixBot
    Aggiungi Commento
  9. PSP 300x Trigger Buttons Replacement: passo 9, immagine 1 di 2 PSP 300x Trigger Buttons Replacement: passo 9, immagine 2 di 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    Chiedi a FixBot
    Aggiungi Commento
  10. PSP 300x Trigger Buttons Replacement: passo 10, immagine 1 di 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
    Chiedi a FixBot
    Aggiungi Commento
  11. PSP 300x Trigger Buttons Replacement, Trigger Buttons: passo 11, immagine 1 di 1
    • Remove the screw securing 'L' trigger to the PSP.
    Chiedi a FixBot
    Aggiungi Commento
  12. PSP 300x Trigger Buttons Replacement: passo 12, immagine 1 di 1
    • Remove the white plastic piece that holds the 'L' trigger in place.
    Chiedi a FixBot
    Aggiungi Commento
  13. PSP 300x Trigger Buttons Replacement: passo 13, immagine 1 di 1
    • Remove the 'L' trigger from the PSP.
    Chiedi a FixBot
    Aggiungi Commento
  14. PSP 300x Trigger Buttons Replacement: passo 14, immagine 1 di 1
    • Remove the screw securing the 'R' trigger.
    Chiedi a FixBot
    Aggiungi Commento
  15. PSP 300x Trigger Buttons Replacement: passo 15, immagine 1 di 1
    • Remove the white plastic piece that holds the 'R' trigger in place.
    Chiedi a FixBot
    Aggiungi Commento
  16. PSP 300x Trigger Buttons Replacement: passo 16, immagine 1 di 1
    • Remove the 'R' trigger from the PSP.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
cmcevill
Membro da: 11/05/09
541 Reputazione
Una guida realizzata
Cal Poly, Team 19-2, Maness Fall 2009 Membro di Cal Poly, Team 19-2, Maness Fall 2009
CPSU-MANESS-F09S19G2
3 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 36
Ultimi 30 giorni: 214
Tutti i Tempi: 24,623
