Salta al contenuto principale
PSP 2000 Memory Stick Slot Replacement
Cosa ti serve
    1. PSP 2000  Memory Stick Slot Replacement, Battery: passo 1, immagine 1 di 3 PSP 2000  Memory Stick Slot Replacement, Battery: passo 1, immagine 2 di 3 PSP 2000  Memory Stick Slot Replacement, Battery: passo 1, immagine 3 di 3
      • Place PSP face down, so that the UMD Drive is facing upwards.
      • Locate the battery door and open.
      • Remove the battery from inside.
      Chiedi a FixBot
      Aggiungi Commento
    1. PSP 2000  Memory Stick Slot Replacement, Front Casing: passo 2, immagine 1 di 1
      • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
      • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
      • Remove the sticker using the PSP Opening Tools.
      • Under the sticker is a 5mm Phillips screw needed in the next step.
      Chiedi a FixBot
      Aggiungi Commento
    2. PSP 2000  Memory Stick Slot Replacement: passo 3, immagine 1 di 2 PSP 2000  Memory Stick Slot Replacement: passo 3, immagine 2 di 2
      • Remove four 5 mm Phillips from the case.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      Chiedi a FixBot
      Aggiungi Commento
    3. PSP 2000  Memory Stick Slot Replacement: passo 4, immagine 1 di 2 PSP 2000  Memory Stick Slot Replacement: passo 4, immagine 2 di 2
      • Remove the following screws from around the bezel:
      • Two 4 mm Phillips
      • One 5 mm Phillips
      • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
      Chiedi a FixBot
      Aggiungi Commento
    4. PSP 2000  Memory Stick Slot Replacement: passo 5, immagine 1 di 2 PSP 2000  Memory Stick Slot Replacement: passo 5, immagine 2 di 2
      • Gently pry the front bezel away from the casing using a PSP opening tool.
      • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
      • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
      Chiedi a FixBot
      Aggiungi Commento
    1. PSP 2000  Memory Stick Slot Replacement, Display: passo 6, immagine 1 di 3 PSP 2000  Memory Stick Slot Replacement, Display: passo 6, immagine 2 di 3 PSP 2000  Memory Stick Slot Replacement, Display: passo 6, immagine 3 di 3
      • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
      • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
      Chiedi a FixBot
      Aggiungi Commento
    2. PSP 2000  Memory Stick Slot Replacement: passo 7, immagine 1 di 3 PSP 2000  Memory Stick Slot Replacement: passo 7, immagine 2 di 3 PSP 2000  Memory Stick Slot Replacement: passo 7, immagine 3 di 3
      • With the home bar out of the way, gently pry up the display using the opening tools.
      • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
      • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
      • Gently lift out the display.
      Chiedi a FixBot
      Aggiungi Commento
    1. PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: passo 8, immagine 1 di 3 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: passo 8, immagine 2 di 3 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: passo 8, immagine 3 di 3
      • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
      • Slide off the left trigger along with the plastic bracket underneath.
      • Carefully pry off left trigger button using opening tools.
      • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    2. PSP 2000  Memory Stick Slot Replacement: passo 9, immagine 1 di 2 PSP 2000  Memory Stick Slot Replacement: passo 9, immagine 2 di 2
      • Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally.
      • Gently remove the memory card slot by pulling it straight out.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 20 persone hanno completato questa guida.
espinks
Membro da: 10/18/09
3.887 Reputazione
5 guide realizzate
Cal Poly, Team 6-3, Maness Fall 2009 Membro di Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Membri
108 guide realizzate
2Commenti sulla guida
Thank you, i'am Zakaria Farid from Morocoo
swat4ever2015 - Rispondi Condividi
would this work for a 2001 model?
James Ginther - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 52
Ultimi 30 giorni: 258
Tutti i Tempi: 32,895
