Salta al contenuto principale
PDP Rematch Faceplate Replacement
Cosa ti serve
  1. PDP Rematch Faceplate Replacement, Faceplate: passo 1, immagine 1 di 2 PDP Rematch Faceplate Replacement, Faceplate: passo 1, immagine 2 di 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    Chiedi a FixBot
    Aggiungi Commento
  2. PDP Rematch Faceplate Replacement: passo 2, immagine 1 di 2 PDP Rematch Faceplate Replacement: passo 2, immagine 2 di 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    Chiedi a FixBot
    Aggiungi Commento
  3. PDP Rematch Faceplate Replacement: passo 3, immagine 1 di 2 PDP Rematch Faceplate Replacement: passo 3, immagine 2 di 2
    • Gently lift off the hard cover with your hand; it should not need much force.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 61
Tutti i Tempi: 803
