Salta al contenuto principale
P-Tex Repair
Cosa ti serve
  1. P-Tex Repair, Binding: passo 1, immagine 1 di 3 P-Tex Repair, Binding: passo 1, immagine 2 di 3 P-Tex Repair, Binding: passo 1, immagine 3 di 3
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
    Chiedi a FixBot
    Aggiungi Commento
  2. P-Tex Repair: passo 2, immagine 1 di 2 P-Tex Repair: passo 2, immagine 2 di 2
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
    Chiedi a FixBot
    Aggiungi Commento
  3. P-Tex Repair: passo 3, immagine 1 di 2 P-Tex Repair: passo 3, immagine 2 di 2
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
    Chiedi a FixBot
    Aggiungi Commento
  4. P-Tex Repair: passo 4, immagine 1 di 3 P-Tex Repair: passo 4, immagine 2 di 3 P-Tex Repair: passo 4, immagine 3 di 3
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
    Chiedi a FixBot
    Aggiungi Commento
  5. P-Tex Repair, P-Tex Repair: passo 5, immagine 1 di 3 P-Tex Repair, P-Tex Repair: passo 5, immagine 2 di 3 P-Tex Repair, P-Tex Repair: passo 5, immagine 3 di 3
    • Turn the snowboard over so the bottom of the board is facing up.
    • Set the snowboard down on a stable work surface so that it does not rock or move.
    • We recommend using a table that is small enough to fit between the curves on either side of the board, or placing blocks of wood to raise the board from the table.
    • Assess the damage. If there are loose strands of material around the hole, slice them off carefully with a razor blade.
    • Remove any extra wax with a metal scraper.
    • Use 150 grit sandpaper to roughen up the inside of the gouge.
    Chiedi a FixBot
    Aggiungi Commento
  6. P-Tex Repair: passo 6, immagine 1 di 2 P-Tex Repair: passo 6, immagine 2 di 2
    • Clean the gouge with a few drops of citrus based cleaner such as Orange-Sol (rubbing alcohol will also work), and a small wire brush to get rid of any dirt or rocks. Let the cleaner dry completely—about 20 minutes to an hour.
    Chiedi a FixBot
    Aggiungi Commento
  7. P-Tex Repair: passo 7, immagine 1 di 2 P-Tex Repair: passo 7, immagine 2 di 2
    • Using a propane torch or a butane lighter, heat up one tip of the P-Tex candle over a metal pan.
    • Use caution not to burn yourself - the flame is extremely hot.
    • Wait until the candle is flaming, which may take a couple of seconds.
    • Black carbon flakes will appear in the burning tip. DO NOT let them get into your base or the P-Tex will bond poorly.
    • Let the candle drip onto a metal pan and roll the molton tip around until the candle is carbon free.
    Chiedi a FixBot
    Aggiungi Commento
  8. P-Tex Repair: passo 8, immagine 1 di 2 P-Tex Repair: passo 8, immagine 2 di 2
    • It is important that the P-Tex is flowing and not dripping. Dripping will allow more impurities to enter the bonding surface and inhibit adhesion.
    • Move the molten P-Tex candle to the gouge. Hold it close to the surface and let it flow continuously into the gouge surface.
    • The P-Tex will shrink as it cools, so overfill the gouge.
    • Let the P-Tex cool for about 15 minutes.
    Chiedi a FixBot
    Aggiungi Commento
  9. P-Tex Repair: passo 9, immagine 1 di 3 P-Tex Repair: passo 9, immagine 2 di 3 P-Tex Repair: passo 9, immagine 3 di 3
    • Take a sharpened metal scraper or razor blade and hold it at a 45° angle. Pull the razor using short, overlapping strokes (about a half inch at a time) to remove all material that is protruding above the base of the snowboard. Use whatever direction works best.
    • The razor is sharp and can cut you if you are not careful.
    • You can also wrap sandpaper around a block and rub the area to flatten it completely.
    Chiedi a FixBot
    Aggiungi Commento
  10. P-Tex Repair: passo 10, immagine 1 di 1
    • When the P-Tex is smooth and flush with the base, your repair is finished. Take a couple of seconds to admire your work.
    • Wax your board before use.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 17-4, Forte Winter 2014 Membro di Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Membri
11 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 44
Tutti i Tempi: 4,156
