Introduzione
Replacing the spring can be somewhat difficult, so be prepared to deal with a little frustration when removing the spring.
Cosa ti serve
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Insert the tweezers between the spring and the bottom of the lever to release the spring.
