Salta al contenuto principale
Oster 6329 Bread Grabber Spring Replacement
Cosa ti serve
    1. Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: passo 1, immagine 1 di 2 Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: passo 1, immagine 2 di 2
      • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
      Chiedi a FixBot
      Aggiungi Commento
    2. Oster 6329 Bread Grabber Spring Replacement: passo 2, immagine 1 di 1
      • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
      Chiedi a FixBot
      Aggiungi Commento
    3. Oster 6329 Bread Grabber Spring Replacement: passo 3, immagine 1 di 1
      • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
      • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    4. Oster 6329 Bread Grabber Spring Replacement: passo 4, immagine 1 di 2 Oster 6329 Bread Grabber Spring Replacement: passo 4, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
      Chiedi a FixBot
      Aggiungi Commento
    5. Oster 6329 Bread Grabber Spring Replacement: passo 5, immagine 1 di 2 Oster 6329 Bread Grabber Spring Replacement: passo 5, immagine 2 di 2
      • Lift the top outer metal shell.
      • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
      Chiedi a FixBot
      Aggiungi Commento
    1. Oster 6329 Bread Grabber Spring Replacement, Bread Grabber Spring: passo 6, immagine 1 di 1
      • Press down on the toaster handle to access to the grabber spring located behind the large metal plate.
      Chiedi a FixBot
      Aggiungi Commento
    2. Oster 6329 Bread Grabber Spring Replacement: passo 7, immagine 1 di 1
      • Locate the grabber spring.
      Chiedi a FixBot
      Aggiungi Commento
    3. Oster 6329 Bread Grabber Spring Replacement: passo 8, immagine 1 di 1
      • Use the large needle nose pliers to unwind the grabber spring from one side of the carriage to remove.
      • Repeat this step for the opposite side.
      Chiedi a FixBot
      Aggiungi Commento
    4. Oster 6329 Bread Grabber Spring Replacement: passo 9, immagine 1 di 1
      • Remove the old spring from the toaster unit to insert new.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 13-15, Regan Winter 2014 Membro di Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 30
Tutti i Tempi: 1,292
