Salta al contenuto principale
Optoma HD72 Projection Lamp Replacement
Cosa ti serve
  1. Optoma HD72 Projection Lamp Replacement, Projection Lamp: passo 1, immagine 1 di 1
    • Use a Phillips screwdriver to loosen the single captive 2 mm screw that secures the small lamp panel on the lower case.
    • Remove the panel.
    Chiedi a FixBot
    Aggiungi Commento
  2. Optoma HD72 Projection Lamp Replacement: passo 2, immagine 1 di 1
    • Use a Phillips screwdriver to loosen the two 2 mm screws on the bottom of the projection lamp housing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Optoma HD72 Projection Lamp Replacement: passo 3, immagine 1 di 2 Optoma HD72 Projection Lamp Replacement: passo 3, immagine 2 di 2
    • Lift the panel off of the device using the metal handle.
    • Disconnect the pink wires from the black plastic housing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Optoma HD72 Projection Lamp Replacement: passo 4, immagine 1 di 3 Optoma HD72 Projection Lamp Replacement: passo 4, immagine 2 di 3 Optoma HD72 Projection Lamp Replacement: passo 4, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the four 2 mm screws that secure the lamp to its housing.
    • Remove the projection lamp casing by gently lifting the bulb from its housing.
    Chiedi a FixBot
    Aggiungi Commento
  5. Optoma HD72 Projection Lamp Replacement: passo 5, immagine 1 di 2 Optoma HD72 Projection Lamp Replacement: passo 5, immagine 2 di 2
    • Once the bulb is out, replace it with another bulb and re-secure the housings in reverse order to this guide.
    • The second photo is what the completed bulb housing should look like.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 34
Tutti i Tempi: 280
