Salta al contenuto principale
Optoma HD20 Focal Lens Replacement
Cosa ti serve
    1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 1 di 2 Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 2 di 2
      • Twist the focal cap clockwise until it is fully extended.
      • Remove the focal cap by pulling it straight out.
      Chiedi a FixBot
      Aggiungi Commento
    2. Optoma HD20 Focal Lens Replacement: passo 2, immagine 1 di 1
      • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
      Chiedi a FixBot
      Aggiungi Commento
    3. Optoma HD20 Focal Lens Replacement: passo 3, immagine 1 di 1
      • Use a plastic opening tool to gently pry the top cover off of the device.
      • It is easier to pry off the cover from the back side just above the HDMI ports.
      Chiedi a FixBot
      Aggiungi Commento
    4. Optoma HD20 Focal Lens Replacement: passo 4, immagine 1 di 1
      • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
      • Remove the ribbon by disconnecting it from the main circuit board.
      • Lift up the clip holding it down and pull the ribbon out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Optoma HD20 Focal Lens Replacement, Focal Lens: passo 5, immagine 1 di 1
      • Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
      Chiedi a FixBot
      Aggiungi Commento
    2. Optoma HD20 Focal Lens Replacement: passo 6, immagine 1 di 1
      • Remove the focal lens by twisting it clockwise until it comes off.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Trever
Membro da: 01/22/15
1.282 Reputazione
6 guide realizzate
Cal Poly, Team 21-23, Maness Winter 2015 Membro di Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 41
Tutti i Tempi: 4,855
