Salta al contenuto principale
Oppo X9000 Power Button Replacement
Cosa ti serve
  1. Oppo X9000 Power Button Replacement, Removing the Back Cover: passo 1, immagine 1 di 2 Oppo X9000 Power Button Replacement, Removing the Back Cover: passo 1, immagine 2 di 2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  2. Oppo X9000 Power Button Replacement, Removing the Battery: passo 2, immagine 1 di 1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
    Chiedi a FixBot
    Aggiungi Commento
  3. Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: passo 3, immagine 1 di 2 Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: passo 3, immagine 2 di 2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
    Chiedi a FixBot
    Aggiungi Commento
  4. Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: passo 4, immagine 1 di 2 Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: passo 4, immagine 2 di 2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
    Chiedi a FixBot
    Aggiungi Commento
  5. Oppo X9000 Power Button Replacement, Remove the Newly Exposed Screws: passo 5, immagine 1 di 1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
    Chiedi a FixBot
    Aggiungi Commento
  6. Oppo X9000 Power Button Replacement, Lift off the Back Panel: passo 6, immagine 1 di 2 Oppo X9000 Power Button Replacement, Lift off the Back Panel: passo 6, immagine 2 di 2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
    Chiedi a FixBot
    Aggiungi Commento
  7. Oppo X9000 Power Button Replacement, Remove the Power Button Bracket: passo 7, immagine 1 di 1
    • Use the sharp end of the spudger to pry the power button bracket from the side of the rear case.
    Chiedi a FixBot
    Aggiungi Commento
  8. Oppo X9000 Power Button Replacement, Let the Button Fall Out: passo 8, immagine 1 di 1
    • Rotate the phone onto its side so that the power button falls out with ease.
    • Make sure not to lose the power button.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 4-45, Amido Fall 2014 Membro di Cal Poly, Team 4-45, Amido Fall 2014
CPSU-AMIDO-F14S4G45
5 Membri
22 guide realizzate
1Commento della guida
I am having trouble with my buttons as they no long spring back after i replaced the speaker. They now just sit flush with the body of the phone, both buttons and metal brackets are installed.
Any ideas?
Jake Karp - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 34
Tutti i Tempi: 4,157
