Introduzione
Is your OnePlus Nord N200 not holding a charge as long as it used to, or is it experiencing power issues that suggest a failing battery? If poor battery life, unexpected shutdowns, or failure to charge consistently, it might be time to consider replacing the battery. For a detailed troubleshooting approach, you might find our troubleshooting page helpful
This is a guide on how to replace the battery in the OnePlus Nord N200, also known by its model number DE2118. This guide aims to equip you with the necessary steps and precautions for replacing the battery of your device. You’ll need a set of precision tools and a replacement battery that is compatible with the OnePlus Nord N200. Follow this guide closely to safely replace the battery
Tips and Warnings:
Handle swollen batteries with extreme caution as they can be hazardous. If your battery is swollen, it’s advisable to proceed with replacement immediately and avoid puncturing the battery. Take a look at this guide for more details on what to do with a swollen battery.
Back up data before starting the repair, back up your data to avoid any potential data loss.
Dispose of the old battery properly according to local regulations. Batteries should not be thrown in regular trash due to their toxic and reactive components.
Here is a helpful link on battery disposal.
Cosa ti serve
Insert the Jimmy into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap.
Use a Phillips #00 screwdriver to remove the sixteen 3.6 mm-long screws securing the midframe.
Place a spudger or an opening pick under the connector's edge and pry straight up to disconnect the battery.
Insert iFixit opening pick under speaker assembly.
Lift up the iFixit opening pick to pull out the speaker assembly out of its tray.
Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect the battery.
Pull up on the red tab to begin removing the battery and the tape around it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
