Salta al contenuto principale
One Education Infinity Touchpad Replacement
Cosa ti serve
  1. One Education Infinity Touchpad Replacement, Back Case: passo 1, immagine 1 di 3 One Education Infinity Touchpad Replacement, Back Case: passo 1, immagine 2 di 3 One Education Infinity Touchpad Replacement, Back Case: passo 1, immagine 3 di 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
    Chiedi a FixBot
    Aggiungi Commento
  2. One Education Infinity Touchpad Replacement: passo 2, immagine 1 di 2 One Education Infinity Touchpad Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. One Education Infinity Touchpad Replacement: passo 3, immagine 1 di 3 One Education Infinity Touchpad Replacement: passo 3, immagine 2 di 3 One Education Infinity Touchpad Replacement: passo 3, immagine 3 di 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
    Chiedi a FixBot
    Aggiungi Commento
  4. One Education Infinity Touchpad Replacement, Battery: passo 4, immagine 1 di 3 One Education Infinity Touchpad Replacement, Battery: passo 4, immagine 2 di 3 One Education Infinity Touchpad Replacement, Battery: passo 4, immagine 3 di 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
    Chiedi a FixBot
    Aggiungi Commento
  5. One Education Infinity Touchpad Replacement: passo 5, immagine 1 di 3 One Education Infinity Touchpad Replacement: passo 5, immagine 2 di 3 One Education Infinity Touchpad Replacement: passo 5, immagine 3 di 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
    Chiedi a FixBot
    Aggiungi Commento
  6. One Education Infinity Touchpad Replacement, Solid State Drive: passo 6, immagine 1 di 3 One Education Infinity Touchpad Replacement, Solid State Drive: passo 6, immagine 2 di 3 One Education Infinity Touchpad Replacement, Solid State Drive: passo 6, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
    Chiedi a FixBot
    Aggiungi Commento
  7. One Education Infinity Touchpad Replacement: passo 7, immagine 1 di 3 One Education Infinity Touchpad Replacement: passo 7, immagine 2 di 3 One Education Infinity Touchpad Replacement: passo 7, immagine 3 di 3
    • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
    Chiedi a FixBot
    Aggiungi Commento
  8. One Education Infinity Touchpad Replacement, Motherboard: passo 8, immagine 1 di 2 One Education Infinity Touchpad Replacement, Motherboard: passo 8, immagine 2 di 2
    • Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
    Chiedi a FixBot
    Aggiungi Commento
  9. One Education Infinity Touchpad Replacement: passo 9, immagine 1 di 1
    • Using your fingers, carefully lift up the black tab and then unplug the gold ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  10. One Education Infinity Touchpad Replacement: passo 10, immagine 1 di 1
    • Using a spudger, carefully unplug the black and grey wires by popping them up off the wireless card.
    Chiedi a FixBot
    Aggiungi Commento
  11. One Education Infinity Touchpad Replacement: passo 11, immagine 1 di 1
    • Using your fingers, carefully unplug the two speaker wires from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  12. One Education Infinity Touchpad Replacement: passo 12, immagine 1 di 2 One Education Infinity Touchpad Replacement: passo 12, immagine 2 di 2
    • Using your fingers or an iFixit opening tool, carefully lift the black tab on top of the ZIF connector and remove the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  13. One Education Infinity Touchpad Replacement: passo 13, immagine 1 di 1
    • Using your fingers, carefully lift up the black tab and then unplug the blue ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  14. One Education Infinity Touchpad Replacement: passo 14, immagine 1 di 2 One Education Infinity Touchpad Replacement: passo 14, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the single 4 mm silver screw from beneath the ribbon cable.
    • Using a Phillips #00 screwdriver, remove the two 2.5 mm black screws.
    • Using your fingers, carefully lift the motherboard out of the internal panel.
    Chiedi a FixBot
    Aggiungi Commento
  15. One Education Infinity Touchpad Replacement, Touchpad: passo 15, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the four 2mm silver screws.
    Chiedi a FixBot
    Aggiungi Commento
  16. One Education Infinity Touchpad Replacement: passo 16, immagine 1 di 2 One Education Infinity Touchpad Replacement: passo 16, immagine 2 di 2
    • Peel back the black tape.
    • Using your fingers, carefully lift the metal plate out of the internal panel.
    Chiedi a FixBot
    Aggiungi Commento
  17. One Education Infinity Touchpad Replacement: passo 17, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the two 2mm silver screws.
    Chiedi a FixBot
    Aggiungi Commento
  18. One Education Infinity Touchpad Replacement: passo 18, immagine 1 di 2 One Education Infinity Touchpad Replacement: passo 18, immagine 2 di 2
    • Using your fingers, carefully lift the touch-pad out of the internal panel.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Jason Childers
Membro da: 10/10/19
109 Reputazione
Una guida realizzata
Cal Poly, Team S11-G4, Regan Fall 2019 Membro di Cal Poly, Team S11-G4, Regan Fall 2019
CPSU-REGAN-F19S11G4
3 Membri
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 29
Tutti i Tempi: 540
