Salta al contenuto principale
One Education Infinity Battery Replacement
Cosa ti serve
  1. One Education Infinity Battery Replacement, Back Case: passo 1, immagine 1 di 3 One Education Infinity Battery Replacement, Back Case: passo 1, immagine 2 di 3 One Education Infinity Battery Replacement, Back Case: passo 1, immagine 3 di 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
    Chiedi a FixBot
    Aggiungi Commento
  2. One Education Infinity Battery Replacement: passo 2, immagine 1 di 2 One Education Infinity Battery Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. One Education Infinity Battery Replacement: passo 3, immagine 1 di 3 One Education Infinity Battery Replacement: passo 3, immagine 2 di 3 One Education Infinity Battery Replacement: passo 3, immagine 3 di 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
    Chiedi a FixBot
    Aggiungi Commento
  4. One Education Infinity Battery Replacement, Battery: passo 4, immagine 1 di 3 One Education Infinity Battery Replacement, Battery: passo 4, immagine 2 di 3 One Education Infinity Battery Replacement, Battery: passo 4, immagine 3 di 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
    Chiedi a FixBot
    Aggiungi Commento
  5. One Education Infinity Battery Replacement: passo 5, immagine 1 di 3 One Education Infinity Battery Replacement: passo 5, immagine 2 di 3 One Education Infinity Battery Replacement: passo 5, immagine 3 di 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team S11-G4, Regan Fall 2019 Membro di Cal Poly, Team S11-G4, Regan Fall 2019
CPSU-REGAN-F19S11G4
3 Membri
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 21
Tutti i Tempi: 664
