Salta al contenuto principale
Olympus VR-350 Lens Box Unit Replacement
Cosa ti serve
  1. Olympus VR-350 Lens Box Unit Replacement, Front Plate: passo 1, immagine 1 di 2 Olympus VR-350 Lens Box Unit Replacement, Front Plate: passo 1, immagine 2 di 2
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Olympus VR-350 Lens Box Unit Replacement: passo 2, immagine 1 di 1
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  3. Olympus VR-350 Lens Box Unit Replacement: passo 3, immagine 1 di 3 Olympus VR-350 Lens Box Unit Replacement: passo 3, immagine 2 di 3 Olympus VR-350 Lens Box Unit Replacement: passo 3, immagine 3 di 3
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
    Chiedi a FixBot
    Aggiungi Commento
  4. Olympus VR-350 Lens Box Unit Replacement, Back Plate: passo 4, immagine 1 di 2 Olympus VR-350 Lens Box Unit Replacement, Back Plate: passo 4, immagine 2 di 2
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
    Chiedi a FixBot
    Aggiungi Commento
  5. Olympus VR-350 Lens Box Unit Replacement, LCD Screen: passo 5, immagine 1 di 2 Olympus VR-350 Lens Box Unit Replacement, LCD Screen: passo 5, immagine 2 di 2
    • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
    Chiedi a FixBot
    Aggiungi Commento
  6. Olympus VR-350 Lens Box Unit Replacement: passo 6, immagine 1 di 1
    • Pull the button pad up to fully reveal the visible ribbon cable.
    • You might need to bend the button pad out of the way.
    Chiedi a FixBot
    Aggiungi Commento
  7. Olympus VR-350 Lens Box Unit Replacement: passo 7, immagine 1 di 1
    • Pull out the LCD screen and the ribbon cable.
    • The ribbon cable should be easy to pull out.
    Chiedi a FixBot
    Aggiungi Commento
  8. Olympus VR-350 Lens Box Unit Replacement, Lens Box Unit: passo 8, immagine 1 di 1
    • Remove the metal plate that was underneath the LCD screen by removing the four 4 mm screws with the Phillips PH000 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  9. Olympus VR-350 Lens Box Unit Replacement: passo 9, immagine 1 di 2 Olympus VR-350 Lens Box Unit Replacement: passo 9, immagine 2 di 2
    • Remove the orange ribbon cable from the connector on the left side of the motherboard.
    • To do this, gently lift up the small grey clasp and pull the cable ribbon.
    Chiedi a FixBot
    Aggiungi Commento
  10. Olympus VR-350 Lens Box Unit Replacement: passo 10, immagine 1 di 1
    • There are two other small ribbon cables under the motherboard connected to the lens box. Pull them out from the motherboard.
    • You may need to use force to pull out the ribbon cables.
    Chiedi a FixBot
    Aggiungi Commento
  11. Olympus VR-350 Lens Box Unit Replacement: passo 11, immagine 1 di 1
    • Pull the lens box up and out to remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Brooke
Membro da: 02/23/15
278 Reputazione
Una guida realizzata
USF Tampa, Team 1-3, Leahy Winter 2015 Membro di USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Membri
10 guide realizzate
1Commento della guida
Worked for a SH-21, with a couple of extra screws to remove. Thank you!
Rick Allies - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 43
Tutti i Tempi: 2,338
