Salta al contenuto principale
Olympus Stylus 725 SW Lens Replacement
Cosa ti serve
  1. Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: passo 1, immagine 1 di 3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: passo 1, immagine 2 di 3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: passo 1, immagine 3 di 3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Olympus Stylus 725 SW Lens Replacement: passo 2, immagine 1 di 2 Olympus Stylus 725 SW Lens Replacement: passo 2, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
    Chiedi a FixBot
    Aggiungi Commento
  3. Olympus Stylus 725 SW Lens Replacement, Front Panel: passo 3, immagine 1 di 3 Olympus Stylus 725 SW Lens Replacement, Front Panel: passo 3, immagine 2 di 3 Olympus Stylus 725 SW Lens Replacement, Front Panel: passo 3, immagine 3 di 3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. Olympus Stylus 725 SW Lens Replacement, Side Panels: passo 4, immagine 1 di 3 Olympus Stylus 725 SW Lens Replacement, Side Panels: passo 4, immagine 2 di 3 Olympus Stylus 725 SW Lens Replacement, Side Panels: passo 4, immagine 3 di 3
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  5. Olympus Stylus 725 SW Lens Replacement: passo 5, immagine 1 di 3 Olympus Stylus 725 SW Lens Replacement: passo 5, immagine 2 di 3 Olympus Stylus 725 SW Lens Replacement: passo 5, immagine 3 di 3
    • After removing all four of the screws, pry the side covers off of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  6. Olympus Stylus 725 SW Lens Replacement, Lens: passo 6, immagine 1 di 3 Olympus Stylus 725 SW Lens Replacement, Lens: passo 6, immagine 2 di 3 Olympus Stylus 725 SW Lens Replacement, Lens: passo 6, immagine 3 di 3
    • Unscrew four 2mm long screws using the #00 Phillips screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  7. Olympus Stylus 725 SW Lens Replacement: passo 7, immagine 1 di 3 Olympus Stylus 725 SW Lens Replacement: passo 7, immagine 2 di 3 Olympus Stylus 725 SW Lens Replacement: passo 7, immagine 3 di 3
    • Remove four metal tabs from corners where the 2mm long screws were attached using tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  8. Olympus Stylus 725 SW Lens Replacement: passo 8, immagine 1 di 2 Olympus Stylus 725 SW Lens Replacement: passo 8, immagine 2 di 2
    • Remove the viewfinder lens using a prying device.
    • There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 33-71, Johann Spring 2010 Membro di Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 42
Tutti i Tempi: 5,053
