Salta al contenuto principale
Olympus 850SW Memory Card Replacement
    1. Olympus 850SW Memory Card Replacement, Memory Card: passo 1, immagine 1 di 1
      • Locate the memory card latch/ battery latch on the bottom panel of the camera and open it.
      • Make sure to remove the battery before trying to remove the memory card.
      Chiedi a FixBot
      Aggiungi Commento
    2. Olympus 850SW Memory Card Replacement: passo 2, immagine 1 di 1
      • Hold the memory card so that the pointed wedge is facing up and the sticker is facing the front of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    3. Olympus 850SW Memory Card Replacement: passo 3, immagine 1 di 1
      • Hold the card so that the thicker end of it is to the right, and the flat end is facing the bottom of the camera.
      • Insert the card into the compartment fully until it clicks into place.
      Chiedi a FixBot
      Aggiungi Commento
    4. Olympus 850SW Memory Card Replacement: passo 4, immagine 1 di 1
      • Close the memory card latch/ battery latch.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
1Commento della guida
How much gigabytes can I use on an Olympus 850 SW?
Yuan - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 14
Ultimi 30 giorni: 60
Tutti i Tempi: 3,036
