Salta al contenuto principale
Oculus Rift CV1 Remote Button Replacement
Cosa ti serve
    1. Oculus Rift CV1 Remote Button Replacement, Battery: passo 1, immagine 1 di 3 Oculus Rift CV1 Remote Button Replacement, Battery: passo 1, immagine 2 di 3 Oculus Rift CV1 Remote Button Replacement, Battery: passo 1, immagine 3 di 3
      • Remove the back panel by firmly sliding it towards the strap.
      Chiedi a FixBot
      Aggiungi Commento
    2. Oculus Rift CV1 Remote Button Replacement: passo 2, immagine 1 di 3 Oculus Rift CV1 Remote Button Replacement: passo 2, immagine 2 di 3 Oculus Rift CV1 Remote Button Replacement: passo 2, immagine 3 di 3
      • Push down on the tab under the battery.
      • Firmly slide the battery away from you. The battery should unlatch from its previous position.
      • Once the battery is removed, release the tab.
      Chiedi a FixBot
      Aggiungi Commento
    1. Oculus Rift CV1 Remote Button Replacement, Remote Button: passo 3, immagine 1 di 1
      • Remove the four 4mm Phillips #000 screws from the back of the remote.
      Chiedi a FixBot
      Aggiungi Commento
    2. Oculus Rift CV1 Remote Button Replacement: passo 4, immagine 1 di 1
      • Gently lift the wrist strap to split the back panel into two.
      Chiedi a FixBot
      Aggiungi Commento
    3. Oculus Rift CV1 Remote Button Replacement: passo 5, immagine 1 di 2 Oculus Rift CV1 Remote Button Replacement: passo 5, immagine 2 di 2
      • Gently peel off the top of the control board.
      • Be gentle, if the buttons fall off, try to keep them in the orientation that they were in.
      • If the large black button falls off, place it back into the shell by orienting the tabs on the button to match the holes on the shell.
      Chiedi a FixBot
      Aggiungi Commento
    4. Oculus Rift CV1 Remote Button Replacement: passo 6, immagine 1 di 1
      • Pull the old buttons off and replace them with the new ones.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team S18-G4, White Winter 2019 Membro di Cal Poly, Team S18-G4, White Winter 2019
CPSU-WHITE-W19S18G4
3 Membri
20 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 32
Tutti i Tempi: 1,346
