Salta al contenuto principale
OLPC XO-4 Touch Touchpad Controller Replacement
Cosa ti serve
  1. OLPC XO-4 Touch Touchpad Controller Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside-down, with the handle facing away from you.
    Chiedi a FixBot
    Aggiungi Commento
  2. OLPC XO-4 Touch Touchpad Controller Replacement: passo 2, immagine 1 di 2 OLPC XO-4 Touch Touchpad Controller Replacement: passo 2, immagine 2 di 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
    Chiedi a FixBot
    Aggiungi Commento
  3. OLPC XO-4 Touch Touchpad Controller Replacement: passo 3, immagine 1 di 2 OLPC XO-4 Touch Touchpad Controller Replacement: passo 3, immagine 2 di 2
    • Lift up on the middle of the battery to remove it from the device.
    Chiedi a FixBot
    Aggiungi Commento
  4. OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: passo 4, immagine 1 di 2 OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: passo 4, immagine 2 di 2
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
    Chiedi a FixBot
    Aggiungi Commento
  5. OLPC XO-4 Touch Touchpad Controller Replacement: passo 5, immagine 1 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 5, immagine 2 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 5, immagine 3 di 3
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  6. OLPC XO-4 Touch Touchpad Controller Replacement: passo 6, immagine 1 di 2 OLPC XO-4 Touch Touchpad Controller Replacement: passo 6, immagine 2 di 2
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  7. OLPC XO-4 Touch Touchpad Controller Replacement: passo 7, immagine 1 di 2 OLPC XO-4 Touch Touchpad Controller Replacement: passo 7, immagine 2 di 2
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  8. OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: passo 8, immagine 1 di 2 OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: passo 8, immagine 2 di 2
    • Close and flip the laptop over so you are looking at the battery compartment
    • Remove the five 4mm Phillips #1 screws from inside the battery compartment
    Chiedi a FixBot
    Aggiungi Commento
  9. OLPC XO-4 Touch Touchpad Controller Replacement: passo 9, immagine 1 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 9, immagine 2 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 9, immagine 3 di 3
    • Flip the laptop over, showing the top of the device.
    • Open the laptop and rotate the screen ninety degrees.
    • Tilt the screen so the lower right corner of the screen is closer to the lower case.
    Chiedi a FixBot
    Aggiungi Commento
  10. OLPC XO-4 Touch Touchpad Controller Replacement: passo 10, immagine 1 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 10, immagine 2 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 10, immagine 3 di 3
    • Push in and lift up on the keyboard edge of the white handle piece.
    • Pull the piece towards yourself to remove it from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  11. OLPC XO-4 Touch Touchpad Controller Replacement: passo 11, immagine 1 di 1
    • Remove the four 4mm Phillips #1 screws attaching the green trim to the body of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  12. OLPC XO-4 Touch Touchpad Controller Replacement: passo 12, immagine 1 di 2 OLPC XO-4 Touch Touchpad Controller Replacement: passo 12, immagine 2 di 2
    • Pry off the rear green trim piece.
    Chiedi a FixBot
    Aggiungi Commento
  13. OLPC XO-4 Touch Touchpad Controller Replacement: passo 13, immagine 1 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 13, immagine 2 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 13, immagine 3 di 3
    • Be careful not to pull the bottom portion of the laptop completely off, as there is a cable connecting it to the laptop.
    • Slide the green trim pieces away from the screen.
    • This should release the entire bottom portion of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  14. OLPC XO-4 Touch Touchpad Controller Replacement: passo 14, immagine 1 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 14, immagine 2 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 14, immagine 3 di 3
    • Unplug the cable from the mouse buttons controller to completely remove the lower frame from the device.
    Chiedi a FixBot
    Aggiungi Commento
  15. OLPC XO-4 Touch Touchpad Controller Replacement: passo 15, immagine 1 di 2 OLPC XO-4 Touch Touchpad Controller Replacement: passo 15, immagine 2 di 2
    • Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
    • There may be some adhesive holding the cable to the metal plate. Gently pull the cable off of the plate if it is stuck.
    Chiedi a FixBot
    Aggiungi Commento
  16. OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: passo 16, immagine 1 di 3 OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: passo 16, immagine 2 di 3 OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: passo 16, immagine 3 di 3
    • You should now be looking at the bottom of the lower case.
    • Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
    • Pry off the front and side trim pieces.
    Chiedi a FixBot
    Aggiungi Commento
  17. OLPC XO-4 Touch Touchpad Controller Replacement: passo 17, immagine 1 di 1
    • Remove the two 4mm Phillips #1 screws that attach the mouse buttons controller to the lower frame.
    Chiedi a FixBot
    Aggiungi Commento
  18. OLPC XO-4 Touch Touchpad Controller Replacement: passo 18, immagine 1 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 18, immagine 2 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 18, immagine 3 di 3
    • Disconnect the ribbon cable attached to the keyboard compartment.
    • Unplug the ribbon cable between the touchpad and the mouse buttons controller.
    • Remove the mouse buttons controller from the device.
    Chiedi a FixBot
    Aggiungi Commento
  19. OLPC XO-4 Touch Touchpad Controller Replacement, Touchpad Controller: passo 19, immagine 1 di 1
    • Remove the two 4mm Phillips screws that attach the metal plate to the touchpad assembly.
    • Be sure not to lose the silver magnet in the lower right corner of the touchpad assembly.
    Chiedi a FixBot
    Aggiungi Commento
  20. OLPC XO-4 Touch Touchpad Controller Replacement: passo 20, immagine 1 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 20, immagine 2 di 3 OLPC XO-4 Touch Touchpad Controller Replacement: passo 20, immagine 3 di 3
    • Remove the silver contact tape from the metal plate.
    • Lift the metal plate off of the touchpad assembly.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 3-30, Amido Winter 2013 Membro di Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 30
Tutti i Tempi: 835
