Salta al contenuto principale
OLPC XO-4 Touch Power Button Replacement
Cosa ti serve
  1. OLPC XO-4 Touch Power Button Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside-down, with the handle facing away from you.
    Chiedi a FixBot
    Aggiungi Commento
  2. OLPC XO-4 Touch Power Button Replacement: passo 2, immagine 1 di 2 OLPC XO-4 Touch Power Button Replacement: passo 2, immagine 2 di 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
    Chiedi a FixBot
    Aggiungi Commento
  3. OLPC XO-4 Touch Power Button Replacement: passo 3, immagine 1 di 2 OLPC XO-4 Touch Power Button Replacement: passo 3, immagine 2 di 2
    • Lift up on the middle of the battery to remove it from the device.
    Chiedi a FixBot
    Aggiungi Commento
  4. OLPC XO-4 Touch Power Button Replacement, Screen Frame: passo 4, immagine 1 di 3 OLPC XO-4 Touch Power Button Replacement, Screen Frame: passo 4, immagine 2 di 3 OLPC XO-4 Touch Power Button Replacement, Screen Frame: passo 4, immagine 3 di 3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
    Chiedi a FixBot
    Aggiungi Commento
  5. OLPC XO-4 Touch Power Button Replacement: passo 5, immagine 1 di 3 OLPC XO-4 Touch Power Button Replacement: passo 5, immagine 2 di 3 OLPC XO-4 Touch Power Button Replacement: passo 5, immagine 3 di 3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
    Chiedi a FixBot
    Aggiungi Commento
  6. OLPC XO-4 Touch Power Button Replacement: passo 6, immagine 1 di 1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
    Chiedi a FixBot
    Aggiungi Commento
  7. OLPC XO-4 Touch Power Button Replacement: passo 7, immagine 1 di 2 OLPC XO-4 Touch Power Button Replacement: passo 7, immagine 2 di 2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
    Chiedi a FixBot
    Aggiungi Commento
  8. OLPC XO-4 Touch Power Button Replacement, Screen: passo 8, immagine 1 di 1
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  9. OLPC XO-4 Touch Power Button Replacement: passo 9, immagine 1 di 2 OLPC XO-4 Touch Power Button Replacement: passo 9, immagine 2 di 2
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
    Chiedi a FixBot
    Aggiungi Commento
  10. OLPC XO-4 Touch Power Button Replacement: passo 10, immagine 1 di 3 OLPC XO-4 Touch Power Button Replacement: passo 10, immagine 2 di 3 OLPC XO-4 Touch Power Button Replacement: passo 10, immagine 3 di 3
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
    Chiedi a FixBot
    Aggiungi Commento
  11. OLPC XO-4 Touch Power Button Replacement: passo 11, immagine 1 di 1
    • Remove the screen from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  12. OLPC XO-4 Touch Power Button Replacement, Back Cover: passo 12, immagine 1 di 1
    • Remove the four 6mm screws using a Phillips #1 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  13. OLPC XO-4 Touch Power Button Replacement: passo 13, immagine 1 di 2 OLPC XO-4 Touch Power Button Replacement: passo 13, immagine 2 di 2
    • Rotate the top half of the laptop so that the back cover is facing you.
    • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
    • Remove the back cover by gently lifting it off of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  14. OLPC XO-4 Touch Power Button Replacement, Wireless Card: passo 14, immagine 1 di 3 OLPC XO-4 Touch Power Button Replacement, Wireless Card: passo 14, immagine 2 di 3 OLPC XO-4 Touch Power Button Replacement, Wireless Card: passo 14, immagine 3 di 3
    • When pulling out the connectors, make sure to hold the metal connector instead of the wire.
    • Gently pull out the two antenna connectors by pulling them away from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  15. OLPC XO-4 Touch Power Button Replacement: passo 15, immagine 1 di 1
    • Remove the black 4mm Phillips #1 screw holding the wireless card in.
    Chiedi a FixBot
    Aggiungi Commento
  16. OLPC XO-4 Touch Power Button Replacement: passo 16, immagine 1 di 2 OLPC XO-4 Touch Power Button Replacement: passo 16, immagine 2 di 2
    • Remove the wireless card from the laptop by gently sliding it out of its socket.
    Chiedi a FixBot
    Aggiungi Commento
  17. OLPC XO-4 Touch Power Button Replacement, Motherboard: passo 17, immagine 1 di 3 OLPC XO-4 Touch Power Button Replacement, Motherboard: passo 17, immagine 2 di 3 OLPC XO-4 Touch Power Button Replacement, Motherboard: passo 17, immagine 3 di 3
    • Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
    • Remove the metal cover from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  18. OLPC XO-4 Touch Power Button Replacement: passo 18, immagine 1 di 3 OLPC XO-4 Touch Power Button Replacement: passo 18, immagine 2 di 3 OLPC XO-4 Touch Power Button Replacement: passo 18, immagine 3 di 3
    • Pull the connectors out by holding the plastic tabs and not the wires.
    • Unplug the three wires connecting the motherboard to the bottom half of the laptop.
    • Unplug the two speaker wires from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  19. OLPC XO-4 Touch Power Button Replacement: passo 19, immagine 1 di 3 OLPC XO-4 Touch Power Button Replacement: passo 19, immagine 2 di 3 OLPC XO-4 Touch Power Button Replacement: passo 19, immagine 3 di 3
    • Turn the device over to where the screen used to be.
    • Pull out ribbon cable by holding the purple plastic tab.
    • Pull out connector with the black and white wire by holding plastic tab.
    Chiedi a FixBot
    Aggiungi Commento
  20. OLPC XO-4 Touch Power Button Replacement: passo 20, immagine 1 di 2 OLPC XO-4 Touch Power Button Replacement: passo 20, immagine 2 di 2
    • Move the motherboard slightly to the left so that the audio input and output jacks are out of the frame.
    • Pull the motherboard out of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  21. OLPC XO-4 Touch Power Button Replacement, Power Button: passo 21, immagine 1 di 2 OLPC XO-4 Touch Power Button Replacement, Power Button: passo 21, immagine 2 di 2
    • Remove the power button by pinching in the four tabs until the power button can be pushed out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 3-29, Amido Winter 2013 Membro di Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Membri
20 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 32
Tutti i Tempi: 624
