Salta al contenuto principale
Nvidia Shield TV 1st Generation Controller Battery Replacement
Cosa ti serve
    1. Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: passo 1, immagine 1 di 2 Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: passo 1, immagine 2 di 2
      • Remove the indicated six screws using the T6 Torx screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 2, immagine 1 di 2 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 2, immagine 2 di 2
      • Use the plastic opening tool to pry the face of the controller away from the body.
      • Make sure the controller is face down during this step as the buttons can easily fall out.
      Chiedi a FixBot
      Aggiungi Commento
    3. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 3, immagine 1 di 1
      • Carefully remove the indicated ribbon wires from the face of the controller.
      Chiedi a FixBot
      Aggiungi Commento
    4. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 4, immagine 1 di 2 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 4, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      $3.99
      • Use the angled tweezers to remove the vibration motor cable, moving it upward from its socket.
      • Lift the vibration motor out of the front case.
      • Repeat for the other side.
      • Use the angled tweezers to remove the battery cable, moving it upward from its socket.
      Chiedi a FixBot
      Aggiungi Commento
    5. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 5, immagine 1 di 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 5, immagine 2 di 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 5, immagine 3 di 3
      • Using the T6 Torx screwdriver, remove the indicated eight screws from the logic board.
      • Lift the logic board away from the front case.
      Chiedi a FixBot
      Aggiungi Commento
    6. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 6, immagine 1 di 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 6, immagine 2 di 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 6, immagine 3 di 3
      • Using the T6 Torx screwdriver, remove the indicated four screws from the panel.
      • Remove the panel from the front case.
      • Lift the battery from the front case to remove it.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
USF Tampa, Team S16-G6, Eyestone Fall 2017 Membro di USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
3 Membri
20 guide realizzate
8Commenti sulla guida
Where can i buy the replacement Battery? What tags should i use to find it?
Rancid 3000a - Rispondi Condividi
LC18650 Remote Control accu
djcornelissen - Rispondi Condividi
Are battery packs available for the 2017 controller?
Andrew - Rispondi Condividi
Simply reconnecting the battery fixed my issues
Charles Keisler - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 13
Ultimi 30 giorni: 80
Tutti i Tempi: 21,729
