Salta al contenuto principale
Numark N4 Effect button cover Replacement
Cosa ti serve
  1. Numark N4 Effect button cover Replacement, Numark N4 Disassembly: passo 1, immagine 1 di 1
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Numark N4 Effect button cover Replacement: passo 2, immagine 1 di 1
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
    Chiedi a FixBot
    Aggiungi Commento
  3. Numark N4 Effect button cover Replacement: passo 3, immagine 1 di 1
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
    Chiedi a FixBot
    Aggiungi Commento
  4. Numark N4 Effect button cover Replacement: passo 4, immagine 1 di 1
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
    Chiedi a FixBot
    Aggiungi Commento
  5. Numark N4 Effect button cover Replacement: passo 5, immagine 1 di 1
    • Using your fingers, gently unplug the yellow and red cable as pictured.
    Chiedi a FixBot
    Aggiungi Commento
  6. Numark N4 Effect button cover Replacement: passo 6, immagine 1 di 1
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
    Chiedi a FixBot
    Aggiungi Commento
  7. Numark N4 Effect button cover Replacement, Effect button cover: passo 7, immagine 1 di 1
    • Locate the top right PCB circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  8. Numark N4 Effect button cover Replacement: passo 8, immagine 1 di 1
    • Unplug the two ribbon cables as shown.
    Chiedi a FixBot
    Aggiungi Commento
  9. Numark N4 Effect button cover Replacement: passo 9, immagine 1 di 1
    • Loosen and remove the 11 12mm screws from the circuit board using Phillips #2 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  10. Numark N4 Effect button cover Replacement: passo 10, immagine 1 di 1
    • Carefully remove the circuit board from its housing.
    Chiedi a FixBot
    Aggiungi Commento
  11. Numark N4 Effect button cover Replacement: passo 11, immagine 1 di 1
    • Carefully remove the plastic button covers as depicted.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S13-G11, Cagle Fall 2017 Membro di USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 28
Tutti i Tempi: 808
