Introduzione
It's a simple process to replace the parts of this device. Once you have the device opened, these items can be changed: power button, power cable, heating bowl, and heating coil/pan Etc.
Cosa ti serve
Remove the two 1.3 mm Phillips #2 screws.
Remove the S6 spanner screw.
Remove (flexible) plastic sleeves from the inside end of the power cable.
Inside the product, ensure you look at the power button and try to understand this step before you take action. There are two notches, push them at the same time on both sides to push the button out of the device.
This guide will help you to replace the power button
Altre 3 persone hanno completato questa guida.
