Salta al contenuto principale
Nokia XL Dual Sim Front Camera Replacement
Cosa ti serve
  1. Nokia XL Dual Sim Front Camera Replacement, Back Cover Removal: passo 1, immagine 1 di 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nokia XL Dual Sim Front Camera Replacement, Battery Removal: passo 2, immagine 1 di 2 Nokia XL Dual Sim Front Camera Replacement, Battery Removal: passo 2, immagine 2 di 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: passo 3, immagine 1 di 2 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: passo 3, immagine 2 di 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: passo 4, immagine 1 di 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: passo 4, immagine 2 di 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: passo 4, immagine 3 di 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nokia XL Dual Sim Front Camera Replacement, System components: passo 5, immagine 1 di 1
    • Once the device is open, take note of all the components.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nokia XL Dual Sim Front Camera Replacement, Camera Removal: passo 6, immagine 1 di 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: passo 6, immagine 2 di 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: passo 6, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • With Tweezers, gently unsnap the front camera motherboard connector.
    • The front camera component can now be gently removed.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 1-4, Brown Fall 2014 Membro di USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Membri
14 guide realizzate
1Commento della guida
merci 1000 fois pour ce cite
zmohye - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 23
Tutti i Tempi: 1,436
