Salta al contenuto principale
Nokia X Display Assembly Replacement
Cosa ti serve
  1. Nokia X Display Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nokia X Display Assembly Replacement: passo 2, immagine 1 di 1
    • To remove the battery, simply use your finger to pry the battery out of its slot.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nokia X Display Assembly Replacement: passo 3, immagine 1 di 1
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nokia X Display Assembly Replacement, Display Assembly: passo 4, immagine 1 di 2 Nokia X Display Assembly Replacement, Display Assembly: passo 4, immagine 2 di 2
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nokia X Display Assembly Replacement: passo 5, immagine 1 di 2 Nokia X Display Assembly Replacement: passo 5, immagine 2 di 2
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nokia X Display Assembly Replacement: passo 6, immagine 1 di 1
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 29 persone hanno completato questa guida.
Avery Dorsey
Membro da: 01/21/15
1.894 Reputazione
4 guide realizzate
USF Tampa, Team 6-1, Brown Winter 2015 Membro di USF Tampa, Team 6-1, Brown Winter 2015
USFT-BROWN-W15S6G1
3 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 7
Ultimi 30 giorni: 24
Tutti i Tempi: 6,368
