Salta al contenuto principale
Nokia N900 Camera Replacement
Cosa ti serve
  1. Nokia N900 Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Turn the phone around to the back. Sometimes the phone's back camera slider will not work. If this situation comes about replace your back cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nokia N900 Camera Replacement: passo 2, immagine 1 di 1
    • In the case that you do need a new back cover remove it by locating the slit on the side of the phone allowing you to take off the cover, but if you need to further get to your camera you will need to remove the back cover as well.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nokia N900 Camera Replacement: passo 3, immagine 1 di 1
    • Remove the battery
    Chiedi a FixBot
    Aggiungi Commento
  4. Nokia N900 Camera Replacement: passo 4, immagine 1 di 1
    • Now that we have taken everything off the back of the phone we will need to take a screw driver and take the six screw located on the back out of the phone. This will allow you to take apart the phone in two halves.
    • Camera
    Chiedi a FixBot
    Aggiungi Commento
  5. Nokia N900 Camera Replacement: passo 5, immagine 1 di 1
    • You can use the blue plastic opening tool to remove the motherboard from the back of the phone.
    • The camera is located on the back of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nokia N900 Camera Replacement: passo 6, immagine 1 di 1
    • Your phone should now be able to separate into two pieces. One side being the back of the phone where the camera is located and the other being the side with the touch screen.
    • Back side of the phone where the camera is located
    Chiedi a FixBot
    Aggiungi Commento
  7. Nokia N900 Camera Replacement: passo 7, immagine 1 di 1
    • Here are the two main pieces of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  8. Nokia N900 Camera Replacement: passo 8, immagine 1 di 1
    • The camera can be popped out easily using a blunt knife or credit card. A new camera unit can be put into the same place. In case a Nokia N900 camera unit cannot be found, it is possible to use a Nokia N79 camera without causing damage.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Juan Haro
Membro da: 03/13/14
284 Reputazione
2 guide realizzate
1Commento della guida
Where to find a camera part ?
Thanks
François Soltic - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 15
Tutti i Tempi: 1,566
