Salta al contenuto principale
Nokia 6102i Keyboard Replacement
Cosa ti serve
  1. Nokia 6102i Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Nokia 6102i Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Nokia 6102i Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nokia 6102i Keyboard Replacement: passo 2, immagine 1 di 1
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nokia 6102i Keyboard Replacement, Logic Board: passo 3, immagine 1 di 2 Nokia 6102i Keyboard Replacement, Logic Board: passo 3, immagine 2 di 2
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nokia 6102i Keyboard Replacement: passo 4, immagine 1 di 2 Nokia 6102i Keyboard Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nokia 6102i Keyboard Replacement: passo 5, immagine 1 di 2 Nokia 6102i Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nokia 6102i Keyboard Replacement: passo 6, immagine 1 di 2 Nokia 6102i Keyboard Replacement: passo 6, immagine 2 di 2
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
    Chiedi a FixBot
    Aggiungi Commento
  7. Nokia 6102i Keyboard Replacement, Keyboard: passo 7, immagine 1 di 2 Nokia 6102i Keyboard Replacement, Keyboard: passo 7, immagine 2 di 2
    • Pop out the keyboard from the frame.
    • Once the logic board is removed, the keypad can be easily popped out from the frame with very little force.
    • The picture is showing the three layers: the frame, the keyboard, and the logic board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 23-78, Johann Spring 2010 Membro di Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 21
Tutti i Tempi: 2,213
