Salta al contenuto principale
Nokia 2610 Screen Replacement
Cosa ti serve
  1. Nokia 2610 Screen Replacement, Battery and Sim Card: passo 1, immagine 1 di 3 Nokia 2610 Screen Replacement, Battery and Sim Card: passo 1, immagine 2 di 3 Nokia 2610 Screen Replacement, Battery and Sim Card: passo 1, immagine 3 di 3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nokia 2610 Screen Replacement: passo 2, immagine 1 di 3 Nokia 2610 Screen Replacement: passo 2, immagine 2 di 3 Nokia 2610 Screen Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nokia 2610 Screen Replacement: passo 3, immagine 1 di 3 Nokia 2610 Screen Replacement: passo 3, immagine 2 di 3 Nokia 2610 Screen Replacement: passo 3, immagine 3 di 3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nokia 2610 Screen Replacement, Front Pannel: passo 4, immagine 1 di 2 Nokia 2610 Screen Replacement, Front Pannel: passo 4, immagine 2 di 2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nokia 2610 Screen Replacement: passo 5, immagine 1 di 2 Nokia 2610 Screen Replacement: passo 5, immagine 2 di 2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nokia 2610 Screen Replacement, Screen: passo 6, immagine 1 di 1
    • Remove the 4 screws surrounding the screen using the precision T6 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  7. Nokia 2610 Screen Replacement: passo 7, immagine 1 di 1
    • Lift the screen away from the phone and circuit board.
    • Warning: The screen is attached to the circuit board by a connector on the circuit board, so lift the screen straight up to avoid damage to the connector.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 7-52, Amido Fall 2010 Membro di Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Membri
18 guide realizzate
1Commento della guida
My Nokia 2610 dates from 2005 (or2006) and its screen was very scratched.
I bought a complete front cover replacement from vmobile.pl who were very efficient.
Andrew Wood’s instructions are crystal clear. The phone is as new now.
Many thanks. Andrew Boxall
Andrew - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 41
Tutti i Tempi: 3,668
