Salta al contenuto principale
Nokia 2115i keypad replacement
Cosa ti serve
  1. Nokia 2115i keypad replacement, Nokia 2115i Battery: passo 1, immagine 1 di 3 Nokia 2115i keypad replacement, Nokia 2115i Battery: passo 1, immagine 2 di 3 Nokia 2115i keypad replacement, Nokia 2115i Battery: passo 1, immagine 3 di 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nokia 2115i keypad replacement: passo 2, immagine 1 di 2 Nokia 2115i keypad replacement: passo 2, immagine 2 di 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nokia 2115i keypad replacement, Faceplate: passo 3, immagine 1 di 3 Nokia 2115i keypad replacement, Faceplate: passo 3, immagine 2 di 3 Nokia 2115i keypad replacement, Faceplate: passo 3, immagine 3 di 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nokia 2115i keypad replacement, Removing the Keypad: passo 4, immagine 1 di 2 Nokia 2115i keypad replacement, Removing the Keypad: passo 4, immagine 2 di 2
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Shane
Membro da: 09/30/10
80 Reputazione
6 guide realizzate
Cal Poly, Team 14-38, Forte Fall 2010 Membro di Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 30
Tutti i Tempi: 1,392
