Salta al contenuto principale
Nokero SunRay Pro Power Panel USB Assembly Replacement
Cosa ti serve
  1. Nokero SunRay Pro Power Panel USB Assembly Replacement, Front and Back Case: passo 1, immagine 1 di 1
    • Turn over the device so that the back of the device is facing up.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 2, immagine 1 di 3 Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 2, immagine 2 di 3 Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 2, immagine 3 di 3
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 3, immagine 1 di 2 Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 3, immagine 2 di 2
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 4, immagine 1 di 2 Nokero SunRay Pro Power Panel USB Assembly Replacement: passo 4, immagine 2 di 2
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: passo 5, immagine 1 di 2 Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: passo 5, immagine 2 di 2
    • Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 30
Tutti i Tempi: 508
