Salta al contenuto principale
Nobis NB09 Battery Replacement
Cosa ti serve
    1. Nobis NB09 Battery Replacement, Battery: passo 1, immagine 1 di 1
      • Before beginning this process, make sure the device is powered off.
      • Remove the screws holding the case together.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nobis NB09 Battery Replacement: passo 2, immagine 1 di 3 Nobis NB09 Battery Replacement: passo 2, immagine 2 di 3 Nobis NB09 Battery Replacement: passo 2, immagine 3 di 3
      • Use an opening tool to loosen and pry off the pink back plate.
      Chiedi a FixBot
      Aggiungi Commento
    3. Nobis NB09 Battery Replacement: passo 3, immagine 1 di 2 Nobis NB09 Battery Replacement: passo 3, immagine 2 di 2
      • Remove the black electronic tape covering the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    4. Nobis NB09 Battery Replacement: passo 4, immagine 1 di 1
      • Use the soldering iron to remove the black and red wires from the circuit board.
      • The black wire is the ground and the red wire is the battery positive terminal.
      • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    5. Nobis NB09 Battery Replacement: passo 5, immagine 1 di 2 Nobis NB09 Battery Replacement: passo 5, immagine 2 di 2
      • Gently loosen the adhesive under the battery to avoid damaging it.
      • Use caution; the battery is soft and will bend very easily.
      • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
      • When reassembling, apply adhesive to the back of the new battery.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
1Commento della guida
where can i buy a battery from
Frederick Shipman - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 30
Tutti i Tempi: 3,404
