Salta al contenuto principale
Nintendo Switch Pro Controller Buttons / D-Pad Replacement
Cosa ti serve
  1. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: passo 1, immagine 1 di 1
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
  2. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the handle covers: passo 2, immagine 1 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the handle covers: passo 2, immagine 2 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the handle covers: passo 2, immagine 3 di 3
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: passo 3, immagine 1 di 1
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unclip the plastic cover: passo 4, immagine 1 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unclip the plastic cover: passo 4, immagine 2 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unclip the plastic cover: passo 4, immagine 3 di 3
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the clear plastic cover: passo 5, immagine 1 di 1
    • Remove the clear plastic cover.
  6. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the battery: passo 6, immagine 1 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the battery: passo 6, immagine 2 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the battery: passo 6, immagine 3 di 3
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
  7. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: passo 7, immagine 1 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: passo 7, immagine 2 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: passo 7, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
  8. Nintendo Switch Pro Controller Buttons / D-Pad Replacement: passo 8, immagine 1 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: passo 8, immagine 2 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: passo 8, immagine 3 di 3
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
  9. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the flap: passo 9, immagine 1 di 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the flap: passo 9, immagine 2 di 2
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
  10. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Disconnect the interconnect cable: passo 10, immagine 1 di 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Disconnect the interconnect cable: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
  11. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the front case: passo 11, immagine 1 di 1
    • Remove the front case.
  12. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the screws: passo 12, immagine 1 di 1
    • Remove the two 6.8 mm-long screws on the top circuit board using a Phillips screwdriver.
  13. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the ZIF connector: passo 13, immagine 1 di 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Open the ZIF connector: passo 13, immagine 2 di 2
    • Use a spudger to flip up the locking tab on the ZIF connector.
  14. Nintendo Switch Pro Controller Buttons / D-Pad Replacement: passo 14, immagine 1 di 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: passo 14, immagine 2 di 2
    • Remove the black ribbon cable from its connector.
    • Only a small amount of force should be needed to remove the ribbon cable.
  15. Nintendo Switch Pro Controller Buttons / D-Pad Replacement: passo 15, immagine 1 di 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement: passo 15, immagine 2 di 2
    • Remove the trigger buttons from the plastic cover.
  16. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Unscrew the circuit board: passo 16, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 5 mm-long screw securing the circuit board.
  17. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the board: passo 17, immagine 1 di 2 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the board: passo 17, immagine 2 di 2
    • Remove the circuit board.
  18. Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the button(s): passo 18, immagine 1 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the button(s): passo 18, immagine 2 di 3 Nintendo Switch Pro Controller Buttons / D-Pad Replacement, Remove the button(s): passo 18, immagine 3 di 3
    • Use your fingers or a pair of tweezers to remove the button(s) you wish to replace.
Conclusione
Altre 21 persone hanno completato questa guida.
Cal Poly, Team S11-G2, Regan Fall 2019 Membro di Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Membri
43 Guide realizzate
3 Commenti
On re-assembly, you may have trouble getting the top circuit board and shoulder button support structure to snap into place. It’s easiest to get the circuit board around the right analog stick hole, and push it all the way down until it is in place, then to secure the shoulder button support structure.
Make sure the “Home” button clear plastic light spreader (a clear irregular circle-shaped piece) is in place on top of the home button assembly, or it will give the home button a “sunken” appearance.
nclee - Replica
Worked well, thank you. Had a gooey X button that needed to be cleaned.
Anthony Peacock - Replica
What about the sync button? I've been scouring the Switch Pro Controller guide all day but there's nothing on how to remove the sync button! Mine is in really bad shape from having to use paperclips to press it but i can't find a guide to repair it anywhere.
faye kim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 89
Ultimi 30 Giorni: 456
Tutti i Tempi: 33,936
