Introduzione
This guide is all about installing the rumble motor. The rumble motor is responsible for the vibration you feel in your controller during certain game actions. You may want to use this guide if your controller won't rumble.
Cosa ti serve
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
Repeat for the second lead and wire.
Altre 3 persone hanno completato questa guida.
