Salta al contenuto principale
Nintendo Game Boy Advance SP Speaker Replacement
Cosa ti serve
  1. Nintendo Game Boy Advance SP Speaker Replacement, Prepare your Game Boy for disassembly: passo 1, immagine 1 di 3 Nintendo Game Boy Advance SP Speaker Replacement, Prepare your Game Boy for disassembly: passo 1, immagine 2 di 3 Nintendo Game Boy Advance SP Speaker Replacement, Prepare your Game Boy for disassembly: passo 1, immagine 3 di 3
    • Slide the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge in, remove it.
  2. Nintendo Game Boy Advance SP Speaker Replacement, Remove the battery cover: passo 2, immagine 1 di 2 Nintendo Game Boy Advance SP Speaker Replacement, Remove the battery cover: passo 2, immagine 2 di 2
    • Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Game Boy Advance SP Speaker Replacement: passo 3, immagine 1 di 3 Nintendo Game Boy Advance SP Speaker Replacement: passo 3, immagine 2 di 3 Nintendo Game Boy Advance SP Speaker Replacement: passo 3, immagine 3 di 3
    • Lift the edge of the cover near the screw and remove the cover.
    • During reassembly, hook the tabs on the bottom edge of the cover into their slots and lay the cover into place.
  4. Nintendo Game Boy Advance SP Speaker Replacement, Remove the battery: passo 4, immagine 1 di 3 Nintendo Game Boy Advance SP Speaker Replacement, Remove the battery: passo 4, immagine 2 di 3 Nintendo Game Boy Advance SP Speaker Replacement, Remove the battery: passo 4, immagine 3 di 3
    • Use your finger to lift the battery by the tab on its left edge, then remove it.
    • During reassembly:
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • Your replacement battery may come with a plastic enclosure that slides over the battery.
    • Insert the edge of the battery with contacts at a slight downward angle—aligning the contacts with their prongs in the recess—and press the battery into place.
  5. Nintendo Game Boy Advance SP Speaker Replacement, Remove the bottom shell: passo 5, immagine 1 di 2 Nintendo Game Boy Advance SP Speaker Replacement, Remove the bottom shell: passo 5, immagine 2 di 2
    • Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
    • Four 6.3 mm‑long recessed screws
    • Two 4.6 mm‑long screws
  6. Nintendo Game Boy Advance SP Speaker Replacement: passo 6, immagine 1 di 2 Nintendo Game Boy Advance SP Speaker Replacement: passo 6, immagine 2 di 2
    • Lift the bottom shell straight up and remove it.
  7. Nintendo Game Boy Advance SP Speaker Replacement, Remove the power switch cover: passo 7, immagine 1 di 2 Nintendo Game Boy Advance SP Speaker Replacement, Remove the power switch cover: passo 7, immagine 2 di 2
    • Use your fingers to lift and remove the power switch cover.
    • Use your fingers to put the power switch cover (notched side up) into place so the cutout goes around the actual switch.
    • Gently slide the cover back and forth to make sure it's positioned properly and moving the switch.
    • If the switch isn't properly in its cutout, you won't be able to power on your Game Boy.
  8. Nintendo Game Boy Advance SP Speaker Replacement, Remove the motherboard screws: passo 8, immagine 1 di 2 Nintendo Game Boy Advance SP Speaker Replacement, Remove the motherboard screws: passo 8, immagine 2 di 2
    • Use a JIS 00 screwdriver to remove the three 4.1 mm‑long screws securing the motherboard.
  9. Nintendo Game Boy Advance SP Speaker Replacement, Prop up the motherboard: passo 9, immagine 1 di 3 Nintendo Game Boy Advance SP Speaker Replacement, Prop up the motherboard: passo 9, immagine 2 di 3 Nintendo Game Boy Advance SP Speaker Replacement, Prop up the motherboard: passo 9, immagine 3 di 3
    • Place a sturdy object such as a stack of books or tool case along the edge of your Game Boy with the hinges.
    • Use your fingers to gently flip the motherboard over the hinges and prop it up.
  10. Nintendo Game Boy Advance SP Speaker Replacement, Remove the speaker: passo 10, immagine 1 di 3 Nintendo Game Boy Advance SP Speaker Replacement, Remove the speaker: passo 10, immagine 2 di 3 Nintendo Game Boy Advance SP Speaker Replacement, Remove the speaker: passo 10, immagine 3 di 3
    • Use the point of a spudger or a clean fingernail to lift the speaker until you can grip it with your fingers.
    • Grip the speaker with your fingers and remove it.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
Altre 14 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
149.628 Reputazione
995 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 144
Tutti i Tempi: 22,757
