Salta al contenuto principale
Nintendo 3DS Back Cover Replacement
Cosa ti serve
  1. Nintendo 3DS Back Cover Replacement, Loosen the rear screws: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS Back Cover Replacement, Remove the rear cover: passo 2, immagine 1 di 2 Nintendo 3DS Back Cover Replacement, Remove the rear cover: passo 2, immagine 2 di 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
Conclusione
Altre 19 persone hanno completato questa guida.
David Hodson
Membro da: 04/13/10
152.709 Reputazione
127 Guide realizzate
2 Commenti
Anybody know where to buy replacement back covers for this original 3DS model? I’m finding that a lot of used 3DS’s from this era have 3rd party battery packs and the original cover is lost.
CORED3SIGN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 142
Ultimi 30 Giorni: 488
Tutti i Tempi: 30,160
